Question about RCA 32V550T 32" TV
Rca 32v434t 32"
I have a problem my t.v. cutts on but wont stay on for longer than a minute but if i hold the volume or chanel up or down button its stays on but soon as i let it go it cutts of so wat do i do to fix the problem?.
  • 3 Answers
When cleaning the front of your tv do you spray glass cleaner on the glass? Many time I have seen glass cleaner that has dripped down onto the pc board, contols like power, vol, and channel control are under the tube and there is nothing to protect it from liquid, if it has not eaten the componets from Corsosion there may be a chance that you may be able to clean with flux remover or tuner cleaner. Be very careful when using these cleaners because they can eat plastic.
Posted on Sep 09, 2007
SOURCE:
Wont finish its loading process
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Feb 06, 2014 | RCA Tablets & eReaders
How can i reset the toshiba 61A60
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password.
The V-Chip is bypassed by holding the zero key on the original remote hand unit, and at the sane time holding down the volume down on the front of the TV set. This should reset the oide so you can enter a new one.
Dec 24, 2012 | Toshiba 61A60 TV
My tv is an old rca tv, i have a dish network remote, one of the kids locked out the tv and i dont know how to get it back on, it wont tell me a anything all i can do is change the tv with the remote,...
If I read your post correctly it sounds like, the remote no longer works the volume or power for the TV set. If this is correct follow the steps below for a Power Scan. If this is not the issue or the steps don't work feel free to contact me and we will sort this out!
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Try several functions Mute Volume and Power to make sure the remote works properly then press "SAT".
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | RCA 32F531T 32" TV
RCA 32'' TV
Unfortunately, the Power Supply has spat the dummy out. It is giving enough power to light the LED but not enough to run the set. To replace it will probably cost more than buying a new set. But ask around your local repairers for a price before you make any decisions...
Feb 23, 2010 | RCA F32444 32" TV
RCA 32V434T (32'') TV has no Red or Green pixels, only Blue
The color problems are caused by cracked/broken solder joints on the circuit that controls the display.  Usually this is located at the back of the tube on a small circuit board. Your description suggests that only the blue signal circuit is intact. I suggest these joints be resoldered for more strength.
It's a possibility that another IC senses this problem (or another one) and then shuts down the system.
Resolder those joints and see what happens.
Jun 03, 2009 | Televison & Video
RCA 32v434t loss of power
yepp. throw it away and buy something better than RCA. these sets are the worst RCA ever made.they dont even supply parts during the warranty anymore........
Jan 11, 2008 | Televison & Video
Rca 32v434T need part numbers
The H.O.T. Transistor number (original is 2SD3402 (which is no longer available)) it's replacement is the 2SC5902.
The H.O.T. Transformer part Number is RCA 271996
Oct 30, 2007 | RCA 32V550T 32" TV
RCA 32v434t
Has anyone confirmed what the problem is? Mine wont turn on. The red light next to the power button just stays lit when pressed.
Oct 22, 2007 | RCA 32V420T 32" TV
Rca 32v434t
went in the menu and blocked the panel buttons on accident
Oct 13, 2007 | RCA 32V550T 32" TV
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
RCA 32V550T 32" TV Logo
62 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
