If you have an internet connection using the ethernet cable but not on the wireless and there is an orange light blinking.. Try to reset the router by pressing the reset button located on the back or on the location were you can twist the stand for the router. press it for about 10secs and that will return the router on a factory settings. before u reset the router make sure to acces the configuration for the internet settings of your isp provider. if the orange light still there, try to download the latest firmware of your router on linksys site and that should fix the problem
it means its lost its connection, theres a little reset button near the on off switch normally use a paper clip or safety pin and press for 10 secs and it should start flashing and connect again
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
This is a sign of a bad router already, so if its still under warranty you can go have this unit replace from Linksys , since this is already a hardware problem...
You can never have too much security, however there are some firewalls that will not work with hardware firewalls, that includes the all Linksys Routers . Keeping this in mind, some software firewall will continue working after the router is installed. If it does, it shouldn't need to remove it, because it's an extra layer of security. However if there are difficulties using the Internet with the Software firewall after installing the router, try disableing it to see if internet is accessable. If the internet works after disabling the software firewall, then remove the firewall.
