Question about Wacom Graphire 4 "Silver" 4x5 (WMM132369)
Pen is always drawing
I use my Wacom Graphire 4 tablet with Photoshop Elements 6.0 on a new MacBook, with OS X. The mouse works fine, but the pen is not working properly. The pen is always drawing even when I am not touching the tablet..... I would appreciate any advise because I am stuck. Thank you
  • 5 more comments
  • jkmcclure Jan 02, 2008
    I'm a novice with my tablet, however it doesn't seem correct that is ALWAYS drawing. It seems the pointer is incorrect because when I use the pen on non-drawing applications it just highlights everything (instead of just pointing).
    I'm not sure if my nib is correct or incorrect, but it's new and nothing is broken.
    I open up any drawing application and it draws all the time, even when it's hovering above the tablet. How do I get it to draw on pressure or when I want it to draw?
  • Anonymous May 04, 2008
    same here! when i'm trying to draw, it draws a continuous line unless i lift the pen several inches above the tablet. it's very frustrating, and i rebooted the computer and nothing happened. this has never happened before.
  • Chicken Wing May 04, 2008
    yes, i have this problem too. it's never done it before and i've had it a couple years. i don't know how to take out the nib. i also am not sure what number graphire i have. i downloaded the new drive and changed the sensitivity settings but nothing works. it is really frustrating and any good ideas would be appreciated.
  • Bafa Jul 25, 2008
    Same problem, pen keeps drawing, whatever settings I apply. It started since I switched to Vista. Have tried the suggested solutions, but nothing helps. Installed latest driver and tablet service is running. Checked nib and tablet surface for dust. I don't use it a lot, so I doubt the nib is worn out. The Graphire 4 is not Vista certified, does that have something to do with this problem?
  • Anonymous Feb 07, 2009
    Solution #2 is the best, works for me, thanks man, I was going nuts!!
  • hrcarlsen Mar 10, 2009
    Hmmm neither of the solutions helped me out. Can anyone tell me what's going on? I use the same settings as usual, but for some reason the pen keeps [email protected]'%ng drawing.
  • Anonymous Apr 12, 2009
    neither of the solutions work. when i look at the lamp it turns green before it touches the pad, is not only supposed to turn green when it's touching?
Dear All,
I have experienced the same problems in the aforementioned cases about the pen randomly highlighting things on the desktop/making selections, as well as loss of double tapping feature for double clicking. For my situation, I am pleased to say that I've managed to resolve the problem it may or may not help but worth a try. The solution:
(1) go to control panel and open up the 'Pen Tablet' icon,
(2) under 'Tracking' select 'Pen Mode' and click on 'Details' tab,
(3) under 'Screen Area' select 'Monitor' (*IMPORTANT*)
(* other settings I have are: 'unchecked' force proportions, 'Tablet Area' set to 'full', number of monitors under 'Screen Area' set to 1)
Following the above steps should remedy the problem. It worked for me. I hope it proves useful to you as well.
Kindest regards,
Jon
Posted on Jul 29, 2008
  • sbro7
    sbro7 Aug 23, 2013
    this solved my issue thanks
I have the same problem with my Graphire 3 and my brand new macbook. The tablet worked fine for 2 weeks, then started going "crazy".
I downloaded the latest driver from the Wacom site:
http://www.wacom.com/productsupport/select.cfm
And it started working again.
Except the next day, when I came back it was back to crazy again. So I suspect it's a software problem, and not a hardware one.
But I figured a work around. I opened the tablet pen in System Preferences. Voila! The pen is recognised properly and works again! Maybe some smart tech dude and explain why...
But it works for the time being...
Posted on Jun 06, 2008
Its the nib that is causing the problem - did you replace it or take it out recently? try taking it out and making sure that when u replace it or put it back in that nothing (dirt, fluff, whatever) is obstructing the passage way that the nib fits into.
hope this helps
Posted on Nov 10, 2007
SOURCE:
Wacom tablet pen right click always active.
I'm having this same problem with my original Graphire (ET), with a replacement pen that's less than two years old.
I don't think it's a driver issue, based on the indicator light on the tablet itself. It turns green like it's detecting a click when either end of the pen is brought near the tablet. To me, that suggests an issue with the pen hardware. The mouse has no such problem.
I'd be very interested if anyone has a solution to this.
Feb 15, 2010 | Wacom Graphire3 Studio Usb (cte-430/b1)
Bamboo Fun won't work w/ provided software
I had the same problem when I got my laptop (Vista OS). The solution is to update the new driver for your bamboo. They are out of date so you need to go here: http://www.wacom.com/downloads/driver-detail.php?id=196 Updated @ Apr. 9, 2009
This update should allow Vista to find it.
Jun 01, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Wacom tablet clicking noise!!!!!
ok... so i've just been fiddling around with my wacom settings... and i noticed that while i didn't see any sound options when i go to the wacom tablet settings through the windows control panel, i do have them in the pen office program... i had the sound box ticked, so i just unticked it...
Feb 09, 2009 | Wacom Graphire 4 "Silver" 4x5 (WMM132369)
Pen pressure and scale problems
I also use Intuos 3 tablet, did you already try replacing the tip and reconfiguring the pen to the screen? You can find this in the driver software, it synchronizes the pen and tablet.
If you already tried that, does the problem only occur in Photoshop? Also, check your brush preferences, you can go back to your default settings and see. If talking to Wacom fails, you might have a bad pen or tablet.
Jul 07, 2008 | Wacom Intuos3 4x5
My pen cursor jumps all over the place
You may have an issue with the Graphire pen. Try plugging the tablet into another computer and see if the pen does the same thing there. If it behaves the same way on another computer then you need a new pen from Wacom.
Jun 28, 2008 | Wacom Graphire4 Digital Pen
Wacom Graphire Bluetooth stopped working
I didn't see anything specific for a Graphire A5 or a Graphire Bluetooth.
I did find this for a Graphire wireless:
http://www.wacom.com/productsupport/drivers.cfm?os=XP&product=CTEBT&CFID=5186275&CFTOKEN=15531183
There were some drivers on this page that were dated April of 2008. They could have been updated since your purchase
Jun 26, 2008 | Wacom Graphire A5 (CTE630BT) Graphic...
Tablet Pen end not erasing in Photoshop elements
If you're still having trouble with the Wacom pen eraser function in Photoshop, it may interest you to read this http://wcoastsands.blogspot.com/2008/10/wacom-tablet-driver-errata.html
Mar 02, 2008 | Wacom Graphire 4 "Silver" 4x5 (WMM132369)
Pen working incorrectly
I have the exact same problem, and I can't find anything, until now, on the web about it. I think perhaps the pen is defective because the mouse works fine.
Oct 20, 2007 | Wacom Graphire 4 "Silver" 4x5 (WMM132369)
Graphire 3 tablet pen troubles
scrap the graphire and get an intuos....i have the same problem....I think the pens are cheap...you might need a new pen. try borrowing someone with an intuos pen.
Sep 12, 2006 | Wacom (EP130E0W01) Digital Pen
Wacom Graphire 4 "Silver" 4x5 (WMM132369) Logo
1,902 people viewed this question
Top Wacom Computers & Internet Experts
jasbo
jasbo
Alun Cox
Vincent G
Vincent G
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
