Question about GE DGE100N DVD Player
Connection I want to connect the dvd player to my cable box. How can I do that?
  • 3 Answers
Without being able to see the two units...I couldn't begin to guess what you may have there!! There are a myriad of ways to connect video & audio equipment up/together nowadays... the connections vary from unit to unit. The best thing for you to do is; to take both units down to your local electronics outlet, (i.e. Fry's, Bestbuy, Circuit City Etc.), show them the units & tell them what you want to do....they'll hook you up with some cables & some directions on how to properly connect them, so you'll get the best possible entertainment you can get out of them! Good luck & happy clicking!!!
Don
Posted on Feb 14, 2008
Combo VCR/DVD player has no cable connection on back> How do I hook it up, through adigital box, to an older TV with one set of white, yellow and red connections?
What outputs are available on the digital box? If you have composite out (AV), then you connect the yellow (video), red and white (audio) to the VCR composite IN on the DVD player. Then connect the composite out from the DVD player to the TV. You will need an extra RCA composite cable. If you need one, they can be found in most stores. (try an online shop that specializes in cables to avoid an outrageous price). The VCR In is to the Right of the DVD/VCR Out.
If the incoming cable is only available with a coax connection, you will need a set top box and a coax splitter. Connect the incoming coax to the input of the splitter. Then connect one coax cable to the TV antenna/cable in. Connect the other to the set top box and then connect the composite output of the set top box to the VCR composite IN.
The manual and the quick start guide are available as PDFs here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=DVP3345VB/F7 . For diagrams of the connection to a cable or other set top box see the FAQs on the right hand side of the page.
If your cable box has some other output, you will need an appropriate converter to go from component to composite video for example.
I hope this helps.
Apr 22, 2011 | Philips DVP3345VB/F7 DVD Player/VCR
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Dvd connection
Does your cable box have rca jacks on it. If so you can run your cable cord from the wall to the input on the cablebox. Then from the cable box to the dvd. Your cable box should have the audio lines which are red and white. Connect those to the dvd's red and white inputs. And the yellow video cord from the cablebox to the dvd video input. Try that................I hope that was helpful for you..........Please rate this information..........Thank you for using Fixya.com..... : )
Feb 17, 2009 | Mintek DVD-2580 DVD Player
Connecting my tv to cable,vcr and dvd
what is the problem not enough connection areas usually you would connect your VCR to your cable box and set channel three on your cable box for the VCR then using one of your other inputs from your TV for the dvd player . Is your DVD player HDMI or Componet?
Dec 28, 2008 | Televison & Video
WILL NOT PLAY
Hi There, It sounds like the cable people change the connection. For me to help you, I will need a detailed description of every connection, from where it is connected to the other end of the connect along with the name of the connection. Thanks, Mike
Nov 03, 2008 | Memorex MVD2042 DVD Player
Magnavox DVD/VCR Dual
Usually a cable box has a RF (antenna connect) IN (from the external signal) OUT (cable going to the TV_RF in)
Usually one has to place TV_channel on 3 or 6 (my TV ch. 60).
EXTERNAL signal goes in CABLE box RF_in, CABLE box RF_out to the TV (RF_in).
In order to connect DVD/VCR, [IN LINE with cable & TV] just connect the RF_out from CABLE BOX into the RF_in of the DVD/VCR, RF_out of DVD/VCR to the TV RF_in.
Jul 24, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR, DVD, TV Connection
first let me say that a dvd player and a dvd recorder are different. the dvd player can only play dvd while a dvd recorder can both play and record dvd that is said. what i understand from what you write is currently is - out of your tv box into your dvd player then out of your player into your tv........ ok some dvd has two connections. line one and line two if your tv box is in line one then you should plug the rca cable in line two in. then you select line two on the dvd player then plug the other end to your vcr in line out so that is out of your vcr into line two of your dvd player.(some times one of the connection is at the front of your player hidden) if your dvd player only have one connection then you would have to plug out your tv box and replace it with the vcr cable and when you finish coping your vhs tape you plug in back your tv box to your dvd player. hope i could help.......... Tracy
Apr 02, 2008 | Televison & Video
Dvd connection to cable
Connect cable on combo player cable in post to time warner cable box cable out post. and connect the combo player to TV with audio and video patch cords.
Jan 16, 2008 | Samsung DVD-V3500 DVD Player/VCR
GE DGE100N DVD Player Logo
46 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
