Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic PT-47WX42F I have a panasonic PT-47WX42F television. went off and won't come back on . when power button is pushed, power led flashes 3 times. tv stays off. service manual or suggestion would be very helpful.
  • 4 more comments
  • fins Jan 25, 2008
    I am having trouble with the convergence on my TV. Panasonic PT-47WX42F. I have gone in and manually adjusted the color settings on the set up menue. I am still getting about 6" on the right side of the TV that is just all the colors running up and down the screen. Also the colors look like double exposure on the rest of the screen. If you have any other ideas please let me know at [email protected]
  • smspms Jan 28, 2008
    Me too but for PT-51HX42
  • Rayp Feb 28, 2008
    Same problem.
    Power cable off - Power cable on brings on the picture for a second or so and then the red led flashes three times and regular intervals.
  • r_hailey Jun 25, 2008
    I have the Panasonic PT-47WX42F , when I turn it on the red led flases three times and it shuts off and wont come back on.
  • jljames39 Nov 15, 2008
    All of a sudden while Im watching tv the tv turns off and wont come back on. I tried unplugging it and then plugging it back in and as soon as the picture came up the tv turned itself back off. The power light flashes but thats about it.
  • Anonymous Mar 25, 2014
    power indicator flashes orange 2 times
    Sergeant:
    Champion:
  • 375 Answers
Go to servicemanuals.net
Posted on Sep 06, 2007
2 Suggested Answers
SOURCE:
TVtechmaniac
  • 140 Answers
SOURCE: Panasonic PT-47WX42F does not come on
Manual on it's way...Good Luck
Posted on Sep 02, 2007
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX42F does not come on light flashes 3 times HELP!
There is a service manual which should cover this model/chassis series:
Elektrotanya for electronics experts
(PDF format - free - no sign-up needed - 100% clean)
Page 11 ('auto diagnosis feature') shows a table of LED flashes and what each one means. I'd start by checking D-board (since that is power and deflection) and going from there.
Dec 21, 2017 | Televison & Video
47wx42f panasonic tv
Does the led blink when you press power? If so please let me know the number of blinks as that is an error code.
May 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic pt-50dl54j
The 3 times LED code points to no fan rotation. There are 2 fans. Check the larger fan first, p/n = FBL12G12LS, located near the lamp. Even though that fan may be rotating, it may be slow.
thanks
scott
Dec 20, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
711 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
