Question about Gigabyte GA-7VRXP Motherboard
Wont find monitor
Hello i have just joined up and have a problem with my ga-7vrxp motherboard. when i turn my computer on it doesn't find the monitor and i get just a black screen. i have got 256 of ram at the moment in it and have also got a 128 meg g-force graphics card but still no joy, please help if you have any ideas as to the problem, many many thanks dieselwolfie
    President:
  • 317 Answers
Did this happen suddenly, or have you installed any new hardware? Try a different monitor. If you have new hardware, remove it. Your onboard video could have gone out, try a pci video card. Remove all pci cards and try booting. Try a different RAM module if available. If none of these seem to work, your cpu or more likely your motherboard is failing.
Posted on Sep 02, 2007
  • Peter Burns Sep 03, 2007
    So did this fix your problem? what did you do?
No display
If you say the OS is loading, and when the time it goes to desktop it doesn't display. So you have to re-install again your OS because your computer was corrupted either by virus or it was accidentally removed or deleted.
Mar 13, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
My motherboard(ga-6cxc rev 2.0 motherboard) don't show any sign of booting but if i let some part lose it beeps(long) what should I do? even the keyboard don't light up(num lock...) and monitor...
Unplug all of your RAM, expansion cards and IDE/SATA devices. Leave only the processor and the CPU/heatsink plugged in, now try turning it on. If it boots, you should get a ram error, which is normal. If it doesn't boot, either the board, processor, or power supply is bad. Next, reinstall the RAM and start it up again. If it boots again, keep adding parts until you find the one that is causing the problem.
Hope this helps.
Sep 25, 2011 | Gigabyte Slot 1 GA-6CXC-1 Motherboard
After power on beeper beeps 9 times and computer doesn't working. What is it? Motherboard ga-g41m-es2l
error: 9 beeps is ROM checksum
Turn OFF the PC
1.- Clear the CMOS (jumper near the battery)
place the jumper in 2-3
return the jumper to normal position
2. Remove the battery
Turn on
enter to BIOS
Update bios from the Gigabyte web page
remeber rate my answer,,
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Gigabyte GA-G41M-ES2L Motherboard
Forget GA-6VTXE-A bios password.
To Reset the BIOS Password, Remove the CMOS (Coin-cell) Battery from the motherboard for five minutes and restart the system. This will load the factory default settings and the password would be gone.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 22, 2010 | Gigabyte GA-6VTXE-A Motherboard
Wont start monitor
The Gigabyte GA-8PE667 Ultra MB will only run certain AGP graphics cards. Check you manual. See page 1. Click the next link to open your manual; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_8pe667u_e.pdf
To view your manual you'll need the program, Adobe PDF reader.
You can download Adobe here; http://www.adobe.com/products/reader/
If you install anything other than an AGP 4X, (1.5Volt) graphics card. Your system may not boot up normally, if at all. Just because you tested your graphics card in another system does not mean the card is compatible with the GA-8PE667 Ultra. The link below will show a compatible graphics card for your Gigabyte GA-8PE667 Ultra;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3281698&csid=ITD&body=MAIN#detailspecs
Cheers!
Mike
Nov 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
ACPI BIOS attempting to read/write to an illegal IO port address (Ox75/Ox75) which lies in the Ox74-Ox76 protected address range.results in fault in booting. Any advice? Thanks
Check your hard drive for viruses.
If you are running a version of Windows, boot to safe mode and run an anti-virus program. Scan the whole hard drive.
If you do not have any anti-virus program, download or get one and scan the computer.
Oct 09, 2009 | Gigabyte GA-7VRXP Motherboard
Getting the wrong post of cpu type
hello,
Check the bios setting, e.g. processor frequency and the multiplier.
hope this post helps.
Aug 12, 2008 | Gigabyte GA-7VRXP Motherboard
No power up
Re- assemble the processor unit and try. then check your ram is installed correctly and firmly. Try it out with different ram modules. If it work on other modules, Then you have a bad ram.
Dec 04, 2007 | Gigabyte GA-7VAXP Ultra Motherboard
Gigabyte GA-7VRXP Motherboard Logo
60 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Computer Links
steyr1
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
