Question about Compaq Presario 7594 PC Desktop
Removing cover of presario 7594
I've tried several ways to remove this stubborn cover and it is not happening. can you help please.
  • radeshotel Sep 03, 2007
    Thank you so much, I'll give it a shot and let you know.
There are 2 screws inside the feet of the cpu...remove the black rubber feet and the screws are inside it.also remove the screws on the back holding the dust cover in place.
Posted on Apr 21, 2008
Was having the same problem and that moncapitaan's solution worked.
Just removed upper left and right screws and then the one on the bottom from the back. Then I pushed as described and it came right out.
I didn't have the correct kind of screwdriver for the screws but I found one of the tips from a pair of scissors would get them out just fine.
Thanks
Posted on Mar 26, 2008
  • 78 Answers
Hi, Take the 4 or 5 screws out of the back, then grab the top of the front of the case (the bit that ridges up) then pull that while PUSHING against the CD drive. The front and the casing comes FORWARD. These are the most awkard cases I have seen but once you get the gist of it it's easy. Give it a go then let me know. Dont be affraid to pull hard!!!!
Posted on Sep 02, 2007
SOURCE:
How do I get the glass cover over the oven bulb off to change the bulb? The cover turns a 1/4 inch and will not go any further. Pushing or pulling will not help.
Sometimes those glass covers are real hard to turn. Get one of those rubber "mats" or "grippers" designed to help your remove stubborn jar lids (that you can pick up at Ace or True-Value Hardware Stores) and try that. You may also find it helpful to remove the oven door, if the cover is really stubborn.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 15, 2014 | Kenmore 92022 / 92024 / 92025 / 92029...
I Purchased 2 max factor mascara false lash effect befor xmas for myself and daughter and have found it nearly impossible to remove , I use a face wash not soap, when i,ve looked at the mascara it say
Try purchasing a water proof makeup remover that you swipe onto the eyes, that should do the trick. For extremely stubborn mascara, I sometimes resort to a little lotion on a rag or baby oil. If helps it slide off and break away! Good luck
Jan 12, 2013 | Max Factor Health & Beauty
It will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
Removeing the cover of the kp48v90
DO NOT REMOVE COVER (OR BACK). ... MODELS: KP-43T90, KP-48V90, KP-53V90,. KP-61V90 ..... Stubborn stains may be removed with a cloth ... warranty does not cover customer instruction, installation, set up adjustments ...THE RISK OF ELECTRIC SHOCK, DO NOT REMOVE COVER
Jan 24, 2012 | Televison & Video
Clutch tenion spring rubbing derby cover making rubbing sound.
If you've got anything rubbing the derby cover, you've got a real problem somewhere. Go to this site and look up your bike under OEM parts. http://www.bikebandit.com Stand the bike up fairly straight and take the derby cover off. Try to determine what is making the noise and get back with me. If your bike is a Road King or any other Big Twin, the clutch spring is a "diaphragm" type spring meaning it's a flat round disc spring. It's not a coil spring and nothing should be even near the derby cover. The only thing that I can possibly think of rubbing is the clutch adjuster screw lock nut may have come loose and worked it way out far enough to rub but I've never seen that happen because the clutch rotates the wrong way.
Steve
Aug 08, 2011 | 2001 Harley Davidson FLHR - FLHRCI Road...
My "MicroSystem CD" will not start. I've
Hey...if your system is less than a year old it may be covered by the warranty, if not remove the cover to access the inside of unit. Near the power supply inside there is a fuse, it may be blown. Can be found at local electronics supply. Good luck.
May 06, 2011 | Boston Acoustics (MICROSYSTEMCD) Shelf...
Hello; i have a 1971 honda cb750K1,the horn is not working,everything checks out (have power to the leeds) when button is depressed, is there a way to remove horn cover without damaging it to inspect...
Hi there and welcome to FixYa,
Wow that's a vintage bike. Nice.
The coil is probably burnt and there's no way to fix it but replacement. You can try to pry it open to replace it with another horn but it would only ruin it. A vintage horn should be replaced by a similar horn.. I found you a site where you can order the replacement part.
http://www.davidsilverspares.co.uk/CB750K1-FOUR-1971/part_104676/
Hope this helps,
levibit
Dec 25, 2010 | 1971 Honda CB 100
How do i remove the plastic cover over the spark plugs...?
If You grip the cover and wire firmly and pull out hard it should come. They are sometimes very stubborn after having been through repeated heating and cooling cycles. BE CAREFULL it's really easy to gouge yourself or smack your elbow when removing plug wires. I do !!!
Hope this helps you,
RSMITH972278
P.S. PLEASE RATE ME !
Oct 25, 2009 | 2002 GMC Envoy
Shuttle AV42 Motherboard manual
I tried the site you were linked to. The file is there but extremely stubborn.
I have transferred it to another site so you will be able to get it.
HERE
Apr 14, 2008 | Intel Motherboard
Compaq Presario 7594 PC Desktop Logo
181 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
