GE mod no: 27GT630 Chassis no: CTC203AA9
Vertical collaps.
I need the manual, thank
Hello
I've the manual of GE 27GT630 and GE27GT716 with me. Most of the GE & RCA manuals are the same,except in their model numbers. If you want to get it, send me your email address to me, as i cant upload more than 50Kb through this site. Ok
gopakumarg43@ymail.com
Dec 19, 2010 | GE 27GT277 27" TV
Picture tube
no you have no vertical bad chip ic
Oct 21, 2008 | Sanyo DS27820 27" TV
Tv code
I HAVE A YEAR 2003 GE TV
MODEL 27GT630
THE MANUFAFACTURERE WAS THOMPSON LTD
I LOST MY SET UP MANUAL
I HAVE A CABLE
MY GUIDE PLUS REMOTE REFUSES TO WORK AS WHEN I PRESS A KEY THE LIGHT ON THE REMOTE DOES NOT GO ON
I HAVE BEEN USING A REGULAR GE REMOTE AND IT WORKED GREAT
SOME HOW WHEN I TURNED IT OFF YESTERDAY I AM UNABLE TO GET BACK THE TV STATIIONS
I HAVE BEEN FOLLOWING THE SET UP GUIDE ON THE TV
LOCATION CANADA
AREA CODE T9K 2G9
CABLE YES
VCR NO
WHEN I PUT ON THE AUTO CHANNEL SEARCH IT GOES THROUGH THE SETTINGS AND THEN SAYS "NO CHANNELS SELECTED"
IT IS A BEAUTIFUL TV AND I DONT WANT TO DITCH IT
HELP ME
May 13, 2008 | Televison & Video
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
The ITC222 chassis actually has two different boards that are related to the power supply.
(1) Main power filter board #MIS222E0000.00
(2) Power supply #PP222E0000.37
The first board is a small board where the power cord enters. The second board is the large board that the small board plugs into.
Apr 08, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE TV
thats a sign of vertical deflection failure. Try resoldering the vertical output ic. The fall may have cracked the vertical output solder joints or cracked the chassis in the vertical section circuitry.
Apr 01, 2008 | Televison & Video
Field collaps
MAN/WOMAN I GOT SIMILAR PROB. HOWEVER I AM SHORT OF CERTAIN DETAILS. IT IS ALL ABOUT THE VERTICAL SECTION. THIS IS THE PORTION THAT PRODUCES THE FRAME. IC TDA8172 IS USED FOR THIS AMPLIFICATION. CHECK TYPICAL PIN VOLTAGES AND ASSOCIATED CAPACITORS AROUND. CHECK VERTICAL SCAN COIL IMPEDANCE. TRY FURTHER BACK, THE ACTION OF IC CXA2159S. I DO NOT HAVE ITS PIN CONFIG. I NEED IT.OUR PROBLEM IS HINGED AROUND ALL THESE AREAS.
Mar 31, 2008 | Televison & Video
Mitsubishi WS65513
4 1000mf caps on the dm module. replace with equivalent size and temp range. dm mod is inside the vertical standing metal case in left hand side of chassis looking from the back
Feb 19, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Have cable.........but not working
The GE (actually RCA) 31GT659 has the notorious CTC187 chassis. This chassis developes cracks in the solder joints on the shields around the tuner and microprocessor, and can mess up the settings stored in the EPROM IC. This could result in channels going snowy, vertical collapse, loss of sound and/or total shut-down. The set should be resoldered and reprogrammed by someone experienced with this RCA chassis.
Jun 22, 2007 | GE 31GT659 31" TV
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
