Question about Mitsubishi VS-5043 50" Rear Projection Television
Convergence i.c.'s I have a Sony 61" rear projection T.V. model #KP-61s75. I believe I know the problem with it not turning on, the convergence I.C.'s have failed and in turn have blown the fuses, my problem is that Im having problems trying to locate them on my set.I know that it is the B+ supply but dont know where its located and where to follow it down to both I.C.'s and fuses. Can anyone help me out in plain simple directions. Also where can I get these parts besides ordering them from Sony? Thanks in advance!!!!
  • texasdave Sep 03, 2007
    I believe I left out some important info about the set, it does turn on, the L.E.D. flashes 4 times. Sony says that it is No vertical Deflection(sweep) and to check Ic1509 and Q1505 I have been told by several people that it may be a number of problems and Im trying to narrow it down to just a few, with the cost of getting this T.V. to and from the repair shop and the actual repairs I am willing to replace several items that might be the problem
  • texasdave Sep 04, 2007
    Hey, texasdave again, Here is my situation, I dont know much about this rear projection T.V. I have had several different repair shops tell me of several different problems it could be(all are different!!) so now I am really confused, with the prices I have been getting, upwards to $800.00 could I not just order new complete circuit boards and practically give myself a new T.V. on the inside? With everyone telling me different problems and different costs to fix the problem(here locally) it seems it would be less expensive(most of the high cost is labor) and make more sense just to replace all the boards and cover all the bases. Can anyone out there tell me if this is feesible because Im at the point of I dont know who to believe!!!!!!!!!!!!!!!!
    THANKS IN ADVANCE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 398 Answers
The convergence IC's and fuses are not your problem. If the Sony projection set has a bad convergence IC and/or a blown fuse or fuses in the convergence circuit, the set will continue playing but the colors will not line up correctly. If the set will not turn on at all, and has no lights at all on the front of the set, the problem is in your main power supply. If the set tries turning on and then flashes the timer LED on the front of the set, count the number of times the LED flashes, as that is the code for why the set is notworking. I have found that the most common cause of the set not starting is a shorted flyback transformer.
Posted on Sep 03, 2007
SOURCE:
I have a Sony KP-57S510 and need to get to the service menu but dont have the remote. Is there a way around using the remote to access it?
On that model I believe you need an original Sony projection remote or one of the "magic tv remotes" that support the convergence function.
Feb 18, 2013 | Sony KP-57WS510 57" Rear Projection HDTV
61 in. Rear Projection Television convergence will not line up and picture is bow in upper left hand corner
Hi, a common problem with Sony projection CRT TVs is the color convergence circuit, the following link shows you what the repair consists of and what kind of parts are probably involved. It will give you an idea on where to go to in case you want totry the repair yourself . the link: http://www.youtube.com/watch?v=esk4nYZKFcg
Jun 21, 2010 | Sony KP-61XBR300 61" Rear Projection...
The colors are out of alignment on my sony kp-61hs10 how do I fix it?
Ur convergence is dead.Must know how to solders?Must replace 2 STK convergence ICS,and some or all it resistors.Tries these websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 18, 2010 | Sony KP-61HS10 61" Rear Projection...
SONY KP-61XBR38
it could be either convergence or the velocity boards. Are you able to move the red and blue convergence in all four direcctions with the convergence adjustments?
Jul 12, 2008 | Sony KP-61XBR48 61" Rear Projection...
Convergence Settings
Setting the convergence is not a user servicable item. Such adjustments need specialized equipment for proper alignment. Have unit serviced by pro/tech
Apr 05, 2008 | Sony KP-61HS10 61" Rear Projection...
KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Sony KP-61HS10 61" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
