Question about Frigidaire 25 in. FDP750RC Free-standing Dishwasher
Correct Direction of Filter Trap Handle on Frigidaire FDP750RCS0 Disshwasher
Is filter trap handle supposed to face the front of the dishwasher when it is properly installed? Thanks!
Gritty problem on glass and dishes
Posted on Jul 08, 2008
  • 44 Answers
See page 11 of this manual: http://ftp.electrolux-na.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Kinston&PDFtype=Owner&PDFfile=154575201.pdf&model=FDP750RCS1
Posted on Sep 15, 2007
Where are the food traps and filters
Good Afternoon Friend,
I understand you want to know where the food traps and filters are located in your Frigidaire dishwasher, model# PLD2850. The inside of the dishwasher is self- cleaning with normal use. If needed, clean around the tub gasket area with a damp cloth. The filter is self- cleaning. A glass trap located in the center of the filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in glass trap, grasp handle, lift out, empty and replace. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire 24 in. PLD2850 Built-in...
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Clogged drain in frigidaire dish washer
Hello Ian Younker - When did you last clean the filter? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, pits, etc. You should simply be able to grasp handle, lift out, empty and place it back. Also is the unit making a grinding noise? If so, I personally will recommend consulting a professional because you may possibly have a defective drain motor.
Feb 20, 2013 | Frigidaire Gallery Series FGBD2451KF Full...
Help- fridgidare dishwasher will not empty
Hello Monica Ward - Are you referrin that the dishwasher will not drain?
If so, when was the last time the filter was cleaned? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, pits, etc. You should simply be able to grasp the handle, lift out, empty and place it back. Is the unit making a grinding noise? If it is, then contact a professional because you may possibly have a defective drain motor.
Feb 08, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Not drining at all
Hi n_oryniak - Two things to consider...when was the last time the filter was cleaned? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, pits, etc. You should simply be able to grasp handle, lift out, empty and place it back. Is the unit making a grinding noise? If so, contact a professional because you may possibly have a defective drain motor.
Jan 11, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Water not draining
Hello dpolanco9 - Two things to consider...when was the last time the filter was cleaned? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, bones and pits. Simply grasp handle, lift out, empty and place it back. Is the unit making a grinding noise? If so, contact a professional because you may possibly have a defective drain motor.
Dec 09, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher started whinning
Hello - Two things to consider...when was the last time the filter was cleaned? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, bones and pits. Simply grasp handle, lift out, empty and place it back. Is the unit making more like a grinding noise? If so, contact a professional because you may possibly have a defective drain motor.
Oct 20, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher wont pump
Hi - Two things to consider...when was the last time the filter was cleaned? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, bones and pits. Simply grasp handle, lift out, empty and place it back. Is the unit making a grinding noise? If so, contact a professional because you may possibly have a defective drain motor.
Oct 12, 2012 | Frigidaire GLD4050RHS Builtin Dishwasher
I can't remove the glass trap in my frigidaire dishwasher 4ghd2433kf
Try http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/. They didn't have my exact model number so I looked it up by type and found something with enough model numbers matching that it was actually a good match for the manual as well. What worked for me: "To empty the glass trap: 1. Grasp the glass trap's handle and rotate it 900 clockwise while pressing down on the center of the wash arm. 2. Grab the spray arm in the center and lift the spray arm and glass trap assembly up and out from the dishwasher. 3. Tip the assembly over an appropriate container and tap it to empty the glass trap. OR, separate the glass trap - pull the glass trap handle toward you, then up, then further toward you to slide it away from the rest of the assembly; empty it into an appropriate container; then slide the glass trap back into the assembly. 4. Place the assembly back into position, press down on the arm at the center and rotate the glass trap handle 900 counterclockwise being sure the glass trap ends in the orientation shown in the image above. To avoid damage to your unit make sure the spray arm and glass trap are fully snapped in place."
Apr 29, 2012 | Frigidaire Dishwashers
Cleaning the filter on frigidaire ultraquiet dishwasher
Hello Friend,
I see that you are wondering how to clean the filter on your Frigidaire dishwasher, model# FDB1050REC. The inside of your dishwasher is self-cleaning with normal use. If needed, clean around the tub gasket area with a damp cloth.
The filter is self-cleaning. A glass trap located in the center of the filter is designed to collect pieces of broken glass, straws, bones, and pits. To remove this glass trap, grasp the handle, lift out, empty it and replace it. Hope this helps.
-Best Regards-
WP
Feb 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 25 in. FDP750RC Free-standing Dishwasher Logo
409 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
