Question about Texas Instruments BA-20 Calculator
I was given a TI BA-20 but have no user instructions. Where can I go to download a copy of the instructions for using it?
  • 71 Answers
SOURCE: Texas Instruments TI-504511 Calculator
Here you go!
Posted on Oct 14, 2008
SOURCE: Where is the factorial button (x!)
Math button, then over to PRB and it's selection four
Posted on Jul 15, 2009
  • 113 Answers
SOURCE: my texas instruments ti-30Xa doesn't turn on!
It is battery powered. You simply need to replace the battery. This website may help you.
Posted on Aug 03, 2009
  • 360 Answers
SOURCE: texas instruments TI 38 PLUS USAGE
You can download all the manuals at this sites' troubleshooting section too. Plus you can get other great instructions and tips heree too.
Posted on Sep 05, 2009
  • 7983 Answers
SOURCE: Texas instruments TI-83 Plus won't turn on
Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] till it darkens enough.
If that does not solve the problem here is what the TI Knowledge base has to say. Please read till the end. I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If that does not solve the problem, you should contact Texas Instruments at or
Posted on Nov 10, 2009
  • 405 Answers
SOURCE: How to use a Texas Instruments TI-34 calculator
Found the manual for you, there are to download.
1.Quick Reference Guide
2.Guide for Teachers
Follow the link below to download the manuals.
Posted on Apr 10, 2010
Testimonial: "Perfect! Thank you "
0 characters
1 Points
I have lost the owners manual for my Texas Instruments BA-II Plus Calculator, and I need to find another one pronto
You can download it from the manufacturer's support site at
Sep 05, 2011 | Texas Instruments BA-II Plus Calculator
I need a manual for my BA II plus TI calculator
Jan 20, 2011 | Texas Instruments BA-II Plus Calculator
Looking for instruction book for BA-35 solar
You can download the instructions in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from:
Hope this solves your problem. Thanks for using FixYa.
May 07, 2010 | Texas Instruments TI-36X Scientific...
Need a copy of instructions
You can download a Guidebook from
Feb 21, 2009 | Texas Instruments Calculators
Help the the ba 2 plus
You might have to contact Texas Instruments for a paper copy, but for now, I found this for ya. It is a rather large "pdf" though.
Sep 05, 2008 | Texas Instruments BA-II Plus Calculator
How to change the decimal point
Hi - You can download the manual from the following link:
Jul 03, 2008 | Texas Instruments BA-II Plus Calculator
TI-83 instructions
Download a PDF copy from Texas Instruments:
Nov 29, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments BA-20 Calculator Logo
37 people viewed this question
Top Texas Instruments Calculators Experts
Stevan Milanovic
Are you a Texas Instruments Calculator Expert? Answer questions, earn points and help others
