Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Does not begin cycle
Recently moved and the movers were rough on the machine getting it out of it's nook. was on it's side for a bit. Back tot he problem. The machine has a light humming/buzzing sound when it is turned on. The cycle does not begin. When the dial is turned to spin the machine spins, but as I said before the machine does not fill with water. I checked to see that the faucet was turned on propperly.
  • 291 Answers
The buzzing noise sounds like the water valve calling for water.. check your water suppy to washer... dont sound like its getting any water or theres a blockage kinked hose ect.
Posted on Sep 02, 2007
SOURCE:
I have a JUKI DDL-8700N. I recently moved the machine and the movers turned the machine on its side. Now the sewing speed is very fast and it doesn't stop when I take my foot off the pedal.
Carmen, Your belt is either twisted or is not down in the groove in the hand wheel or in the pulley that is on the end of your motor. Use a flashlight to look at the end of your motor (under your table). That is a common problem. Once you think it is probably on both the hand wheel and the pulley, start turning the hand wheel towards you about 10 times. Sometimes that helps it settle in. When this happens, the hinges sometimes get crooked and you will need to try to straighten them by jiggling the head of the sewing machine until it settles in. Good luck.
Dec 07, 2016 | Juki DDL-8700
I have a2011 cub cadet zero turn mower but when I push the left side handle it doesn't barely move . Like theres hardly any power to move the left side. What is a matter with it? Is going to cost alot
May be low on hydraulic Oil.
Theres also a nut that releases the hydro pressure make sure it is not loose. Make sure there are no leaks. And make sure on the back of the mover that the hydro release is not pulled. If there are no issues then there is a issue with the hydro pump and yes the repair is costly. A replacement pump is roughly $250-300 dollars.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
May 21, 2015 | Cub Cadet Garden
Maytag washing machine gets out of balance
Could be broken suspesion leg or spring securing the drum
Sep 27, 2009 | Washing Machines
THE MACHINE SHAKES WITHOUT CONTROL
During the spin cycle if your cloths are too heavy on one side you will get this problem, reposition the cloths and it should cure the problem, at least thats what I do when my machine gets to shaking.
Aug 28, 2009 | Maytag MAH8700A Front Load Washer
Washing machine programme knob has been pushed into machine
Turn the D Shaped spindle with a pair of grips until your machine will do a spin cycle only .
When it can do that put the knob on the shaft with the marker on the knob pointing to the mark on the facia saying Spin
Jun 05, 2009 | Washing Machines
Doors need adjustment
You should be able to take the top trim caps off the door hinges, loosen the hinge screws a little, and move the door(s) away from the center of the refrig, then re-tighten the hinge screws to get the doors to stop hitting each other. You may want to check the bottom hinge(s) for the hight. The bottom hinges and the bottom of the doors have matching plastic "ramped" washers, which raise the door as it is opened, which help them to self close. If one of those is broken, the hight will be off.
Mar 14, 2009 | GE GSH25JFR Side by Side Refrigerator
Hwd1000 washer dryer combo is not moving into the drying cycle
Its time you found out where your filter is to clean out thoroughly
Mar 02, 2009 | Haier HWD1000
Tub spins while in wash cycle
suspect what ge call a mode shifter pull front panel off by sliding putty knife along edge at each side and pressing clips front comes right off look on motor for a flashing green light (washer must be in operation) there are 2 wires in a single plug on motor these run back to transmission area with a volt/ohm meyer unplug and ck between the wires for continuity should be roughly 90 ohms if bad will not show any continuity
Oct 08, 2008 | GE WWSR3090TWW
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
104 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
