Fujitsu 12C1 Air Conditioner
Problem for Fujitsu 12C1 Air Conditioner
Drain must be blocked and water coming out of the
By debbie_belle on Apr 03, 2009
Drain must be blocked and water coming out of the front of the air conditoner. Would like to know how to dismantle to have a look and see if we can give it a clean. A Manual would be handy if possible thanks. Model No. on the Air Conditioner is AST12ASJCW. I was unable to locate it in the product below.
Regards,
Deb.
Best Solution
posted on Apr 04, 2009
Very Helpful)
notsomot
Rank: Guru
Rating: 86%, 41 votes
Heya Deb,
I found the manuals that you where after. I have included a link below.
Althou they dont really help with cleaning of the drain,
http://www.fujitsugeneral.co.nz/manuals.pl?source=Hi-Wall+Range
If you feel confident enough to dismantle the air conditioner please follow my instructions below, how ever if you have any doubt please do not continue.
First off you will need to isolate the power. Turn the air conditioner off at the source, normally at the meter box. Confirm that the power is off. Next under the louver flap is three plastic clips that can be moved to expose three phillips head screws, remove these and put them someone so they are not lost. Next take out the filters. Now what your going to have to do is make sure there are no more screws (locations change from model to model) now pull the cover off from the bottom and unclip it from the top. Remove the cover, you should be able to see the drain clearly now. Pour abit of water in the tray and see where it is leaking from, clean tray if req. Make sure the water exits the drain outside before reassembly.
If you have any problems or questions please contact me
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Fujitsu 12C1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 12C1 Air Conditioner
Do you recommend Fujitsu 12C1 Air Conditioner?
Answer
Answer
the operation and timer lights are flashing while the unit is on
Answer
30,000 BTU has red light blinking three times and does not on.
Answer
when i turn on ac its always on no timer???? is that normal?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 12C1 Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
