Question about GPX HM3817DT Shelf System
Sound I like the sound at 10, which I set every time I turn on the system. I cannot get it to stay on ten. when I turn the system back on it reverts back to 18, which is too loud. How do I set it on 10 to stay after shutting power off
    Scholar:
  • 31 Answers
There are several complaints in FIXYA and they are all about this same fault condition....the volume is too high when turned on...
Because of the high number of complaints about this same fault I would suggest that its a manufacturer fault.
So the manufacturer should be contacted about it to ask for your money back..
Cheers From YUBEUT..
Posted on Dec 04, 2007
Olevia 242-S11. Have to turn tv off and on 6 times before sound stays on. No problem with picture.
Menu , sound settings, disable all special effects , Dolby surround, stereo, etc.. unplug, Wait overnight plug back in see if the problem continues if so, check sound settings they should be the way you left them
Aug 10, 2016 | Olevia Televison & Video
I have a Sony Bravia LCD TV Model: #KDL-46W5100 SN:8020524. When I turn on the TV all it has a great picture & sound. After apx. one minute it will lose the sound and then it will turn itself off. Then...
G'day Lee, sounds like you may have a 'dry joint' meaning the solder has come adrift, to open the back up will need special tools to fix it. Hope you can get it fixed. Cheers Greg.
Mar 04, 2015 | Sony BRAVIA KDL-46W5100 46" 1080p LCD TV -...
How do you use the kitchen timer and cook at the same time?
If you have the kitchen timer set for instance for 10 minutes and it is counting down, and then you want to reheat you coffee for 2 minutes. You would hit either time cook or reheat button and enter 2 minutes ten hit start. The microwave will heat your coffee and show the 2 minute countdown for that. When done it will revert back to what is left on the 10 minute kitchen timer without missing a beat on most microwaves.
Feb 26, 2015 | Microwave Ovens
I have a 2003 chevy malibu that won;t start. When you turn the key to on the Theft System light comes on steady ( no flashing). I t used o go into this mode periodically where the Theft System light...
I have had the same problem. This has happened to me three times in the past nine months or so. Per the owner's manual, you turn the key to the on position and wait about ten minutes. This resets the system and when the "Theft System" light goes out, it starts right up. I did this each time and it started right up.
Jan 02, 2013 | 2003 Chevrolet Malibu
What does it mean when the filter light stays on after the filter has been cleaned?
Generally, it indicates that the unit was not turned off and unplugged before removing and replacing the clean filter.Turn the unit OFF & unplug it for 10 minutes. Then plug it back in and turn it ON. The 10 minute timeout should have give the electronics time to rest and revert back to the original factory settings. if so, you can now set the controls as you like.
Hope this helped you & thanks for choosing FixYa.
Sep 10, 2011 | Heating & Cooling
Hello, I'm trying to increase the volume on some phones mitel 5220 and 5224, but it only goes to 6. I need the volume level to go to 10. Do you have any ideas? Firmware is 07.02.00.04 Thank you
The ADA compliance requires that the phone when set to the highest volume level will revert back to factory default setting for the next call. This is a safety feature to prevent one's hearing aid from being blown up by a loud caller.
If you turn the volume up to 9, and leave it there, it will stay at 9. If you turn it up to 10, it will always revert back to default.
I hope this helps,
Mark
Feb 08, 2011 | Mitel 5220 IP Phone
I just put a new steering column in my 200 saturn sl2 because my ignition lock was messed up. Now when whe try to start the car, it will start up but immediately shut off and then the security light...
Hello: Will try to give you instructions: Attempt to start car, leave key on (security light flashing) let set for 10 minutes, After 10 minutes security light out. Turn key off for ten seconds, turn key on, let set for 10 minutes, turn key off for 10 seconds. turn key back on let set 10 minutes, turn key off for ten seconds, the engine should now start and stay running.
Jan 14, 2011 | Saturn SL2 Cars & Trucks
Home theatre
I had this same problem. All I did was switch the sound type by repeatedly pressing the "SURR." button on the bottom left corner of the remote. Usually after 10 times the sound is back,
Jan 26, 2008 | Philips HTS3440/37 System
Sometimes my audio driver stops responding
Try this test: try repeating the "disconnecting all hardwares like DVDRW,HDD,RAMs,AGP card along with the power cables and then again re-assembled, the sound returns (this time its crystal clear) and this works for few weeks after which the problem occurs again.". Now ensure Windows restore feature is enabled. Then when "problem occurs again", revert the Windows registry back to the date when "its crystal clear". If the sound is crystal clear after restore, then you have a software or registry issue going on. If you don't mind reverting to system restore often, then stay in this recovery mode until your real problem is "crystal clear".
Aug 25, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
GPX HM3817DT Shelf System Logo
56 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
