Home | Acer | Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook | ACER ASPIRE 5610z BLA...
Acer Aspire  5610-4648  PC Notebook
Problem for Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook
ACER ASPIRE 5610z BLACK SCREEN
By Hirmiz on Sep 02, 2007
i bought an acer aspire 5610z and when i turned it on the screen stays black.
can you tell me whats going on or what i can do to solve this problem
Same Problem
Apr 04, 2009
-   i have the same problem, have a aspire 5515 black sceen at boot up green light on fan blowing, black screen all day long-   Guest
Mar 27, 2009
-   same here-   Guest
Sep 27, 2008
-   i replaced the screen on my acer aspire 5610z cause i had a red line running down the right side of mine and after i replaced the screen i turned on the laptop and it was all black there is a picture on the screen it is just very dim i even tried to put the old screen back in and i had the same problem if anyone knows how to fix it i would love to hear from you!-   pgraboyes420
Jul 16, 2008
-   My 5610z is doing the same thing. It will quickly flash the ACER screen when it is booting up but then the screen stays dark. If I take it outside, I can see the images and it seems to be working fine....other than not being able to see the images on the screen. From what I can tell by reading the web is it is either the backlight or the backlight inverter. Can someone help me figure out which it is...and how to fix it.-   thevandams
Jul 08, 2008
-   hi,i hav acer aspire 5710z laptop and camera of laptop is not working.shows "creation of a picture failure." or "Some body use the camera."plz help me-   shak86
Best Solution
posted on Feb 11, 2008
Helpful)
mchipser
Rank: Guide
Rating: 95%, 60 votes
Do you hear any sound when you boot the unit? if so the LCD inverter is most likely the case.. Try connecting a External monitor to the unit and boot the unit. If it works you will see a ACER splash screen but then it might go away when it logs into windows.. By pressing the FN+F5 (i think) it will tell the laptop to output all video to the external
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 11, 2009
Very Helpful)
LeslieSnipes
Rank: Apprentice
Rating: 100%, 3 votes
FIX:
I have an acer aspire 5520G and i can relate all too well. It worked fine for about 3weeks (from brand new!!) then one day the screen went blank while trying to boot. I managed to fix it and it worked fine for almost 2years, untill i went to sell it and encoutered the problem again.
The Fix: this is the fix that worked for me; firstly the problem; this seems to be a big problem with acers for some reason, and there are a few variations or confusions about it when people describe their fault. My fault is that when my laptop is off, i press the power button and the green light comes on, a fan starts up and there is hope, but then the fan changes speed slightly and it stays like that indefinatley, without the screen having ever come on, and i mean the computer is virtually dead except the power light and fan, you cannot press ctrl-alt-del or see the screen from an angle or with a torch. the only thing you can do is hold the power button and force a shutdown, so some deep seeded hardware is still working, but it seems the display never starts and the BIOS never loads.
My first fix - i managed to start my computer by pressing the power button, then as fast as i can (hold function button) repeatadly press F5 and F6 ie. with the function button held you are pressing [Black out screen/Restore Screen] and [Switch Monitors]. this usually starts my laptop on the first or second attempt. The first time i did this i was playing around with external monitor cables and connections, and switching monitors and the problem spontaneously fixed itself as mysteriously as it had arrived.
Second time was extremely frustrating, i could still load my computer by pressing F5 and F6 combos but could not get it to become self sufficent. I upgraded my BIOS with the Flash Updater from acer (i found it on the net) and after the second boot attempt, windows vista installed some memory drivers, and the problem was resolved.
if this hadnt worked i would have tried the memory battery fix as above, as my problem definatly seemed bios related.
Hope this helps someone from loosing their hair.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Dec 05, 2008
Very Helpful)
philkin
Rank: Apprentice
Rating: 100%, 2 votes
I have had a couple of 5610s with corrupt bios causing the unit not to boot or show any screen activity leading you to think the motherboard is faulty, I fixed both these by shorting the bios battery for a couple of seconds. You can get to the battery by removing the access cover over the media card slot then removing a piece of black foam next to the media socket on the motherboard, hiding behind the foam is a small blue bios battery with 2 contacts just visible that you can short out using a small screwdriver. WARNING only do this fix with the main battery removed and no power to the laptop.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Jun 30, 2009
Not Rated)
ialme
Rank: Master
Rating: 90%, 5 votes
Hi Friends,
Acer Aspire 5610-4648 PC Notebook main problem is Web Cam Problem, Windows XP Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
Was this helpful?
Yes
No
Solution #5
posted on Jul 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Is the backlight converter located just below the lcd screen. The LCD cover needs to be removed in order to see the converter.
Model is PK0700005U00-A00-715-15075
Solution #6
posted on Sep 02, 2007
Not Rated)
sandrew
Rank: Wiz  Acer Expert
Rating: 83%, 5925 votes
if you see the led hard disk and power light flickering then you know that the drive is working, so there must be a video or a screen problem.
Shine a torch into the screen and if you can see the pc is booting the backlight converter is faulty and needs replacing, if you see nothing; there may well be a video fault or a faulty screen connection.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5610-4648 PC
Questions and Unsolved Problems for Acer Aspire 5610-4648 PC
Do you recommend Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook?
Answer
Answer
my netbook loads to a point then has a blank screen n stays like that?
Answer
why my webcam @ aspire 5052 didn't work with yahoo messenger?
Answer
hello i want to ask about my cam coz everythime i open cam in yahoo they always said server are busy... (More)
11 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jul 01, 2008
Yea, I turn it on and nothing appears on the screen. The only light I is green and it's the power button.
Comment by needacerhelp, posted on Jun 12, 2008
My screen turns on for a second and then shuts off. I can see that my computer is starting normally. If you take a flash light or something shine it on the screen from the top you can see that the computer is running fine except for the screen. when I shut my screen and open it again the light turns on for a second and shuts off again. I do not know what could have cosed this.
Comment by Guest, posted on May 19, 2008
I get a black screen when booting up. I have tried plugging in another screen and this doesn't do it. I've rebooted several times and nothing.
Comment by Guest, posted on Mar 02, 2008
Black screen troubles here too. I also can not get the computer to shut off or reboot. So I have unplugged it to let the battery wear out and then I'll try to restart it by plugging it back in. This computer is new to me and has worked properly for 24 hours and now has this error.
Comment by RevRafi, posted on Feb 22, 2008
I also have a 5610z Aspire PC Notebook. I hooked it up to a functioning Screen, Pressed the power button,The power light comes on, there is an initial sound of the hard disc trying to boot up, then no sound I tried the FN+F5, move, but the computer does nothing. There is nothing but a black screen.
Comment by Guest, posted on Feb 02, 2008
my computer turns on but there is nothing coming up on the screen and i dont know why
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 5610-4648 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
