Question about PNY Verto GeForce FX 5200, (256 MB) PCI Graphic Card
Not working system said not recemed to install card.
    Novelist:
    Scholar:
  • 167 Answers
It is because the driver verifier may have found that your driver has not passed the microsoft logo check. But it is safe to install the driver if it came bundled with the hardware.
Posted on Nov 03, 2007
SOURCE:
There is no sound in my system. I have checked the speakers they r ok. formatted the system still no sound. checked with usb sound card. still no sound
You must install the correct sound card driver, or it will not work. Find the make and model of your sound card go to their website download the driver for your card and operating system and install this should fix the problem. If not your card may be bad...
Feb 24, 2011 | Computers & Internet
Sound card is fully failed
kindly inform us also about the system or sound card you have installed. also indicate the installed operating system. you could also give us some history like has it worked before or is it a new sound card installed etc. someone will assist you.
regards
Aug 18, 2010 | Computers & Internet
How to install graphic card my computer\nr
Try to plug the graphic card in daughter card slot of mother board Then start your system, if you are using windows xp, Vista and windows 7 Then may be possible that it will automatically install the driver other wise you can insert the graphick card installation disk in cd/dvd drive and install the driver then reboot the system and it will work fine.
Mar 19, 2010 | Intel XFX GeForce2 MX400 (64 MB) Graphic...
My card reader has stoped working how can i get it to read my memory cards agian
First check if other memory cards is working on the system so you can isolate the problem if the card reader slot is faulty or the memory card itself..If other memory card is also not working then we can say that the card reader slot is faulty..There are also 2 scenarios it can be the hardware itself or the driver installed on it..Check the BIOS of the computer is memory card slot is detected..If detected log on to windows and check device manager if card slot is properly installed..Update the driver if there's newer driver for the card slot..You can also try to perform system restore and pray it will work..If those steps don't work..You need to tear down the computer and take out the card slot and try to different known good system..If card slot still doesn't work..better purchase a new one.. Hope this will help..:)
Feb 02, 2010 | Microsoft Windows? Vista Home Premium...
Display issue can card's cmos (if any), be reset?
There is no bios on the AGP card. Uninstall the PowerColor driver software including any other software the CD may have installed. Than open this link;
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
Download RegCure & install. Let RegCure clean your system.
Shut down the system & install your AGP x1550 card. Re-install the driver software. Try playing the game with default settings. Your system & AGP card has more than enough power to play the game. If the game messes up or your system freezes send it back to PowerColor. Its not your system it has to be the card.
Cheers
May 07, 2009 | Power Color POWERCOLOR ATI RADEON VC X1550...
Audio Driver
I have one HCL Busybee 2000 with windows 98. I have upgraded it to XP Provisional. Now the sound system is not working How can it be rectified. While working windows 98 the system hangs, so the sound disabled. Now how can it be enabled?
Apr 16, 2009 | Computers & Internet
Installed a new Sound Card which does not work.
i think it will only run 1 card at a time so you will need to disable or uninstall the reaktek?
Mar 01, 2009 | Computers & Internet
My audio device has a problem
I completed an install of a Creative SB Live! 5.1 on Windows XP pro 32 bit, SP3, with a P4 Intel 850 board. First I updated the bios. Then I had to bypass the windows auto driver install, because this always failed in the past. I disabled plug & play in the Services console (Control Panel/Admin Tools/Services) and shutdown. Then I inserted the card into a different PCI slot (note: my previous issues with audio cards leads me to suspect that certain PCI slots may be assigned automatically to specific IRQs and resources. I think it may be possible that the card may only work in one or 2 of the PCI slots on the system, -but I'm not sure of this). Anyway, I rebooted the system and installed the Creative SB Live drivers from the cd that came with the product. I installed drivers only and rebooted. There was no sound. I enabled Plug& Play in the Services console and started the service. Windows detected a game port and a PCI slot and automatically installed it then prompted me to restart. I was a little wary of the automatic install, but when I restarted the system my card was working and I had sound! Also, I previously enabled audio in the bios, it was originally disabled when I had problems. Although there is no built in audio ports on the system board I think there is an audio processing device resident on the motherboard. Audio cards can be tricky, but when you make all the right moves, they should install and work properly. The trick with the Creative card, I think, is that the Windows plug & play drivers don't work 100% with all systems and you need to find a way to get the proprietary drivers installed first.
Dec 21, 2008 | Computers & Internet
Audio for VIA VT1617A dound card does not work
please install the driver it is available at www.driverguide.com or at the company`s website
Aug 14, 2008 | Edirol UA-4FX External Sound System
LG KG920
DİLİ NASIL DEĞİŞTİRECEM
Feb 29, 2008 | LG KG920 Cellular Phone
Open Questions:
See all PNY Verto GeForce FX 5200, (256 MB) PCI Graphic Questions
PNY Verto  GeForce  FX 5200, (256 MB) PCI Graphic Card Logo
62 people viewed this question
Top PNY Computers & Internet Experts
Thomas F. Schneider
1400Slugg
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
