Light goes on and off
We turn on projector, fan works, light comes on, fan is on high working properly, it runs for 6 minutes, then only the light goes off and the fan stays on (in high position) and within 1-2 minutes the light comes back on and runs for another 5-6 minutes and the light goes off again. Can the thermal switch be bad? We think unit is cooling properly. When turned on and then off fan runs in low position, working properly also.
    Master:
    Sergeant:
  • 482 Answers
If the power comes on the power box, that is good, so the only the is the mother board is bad, replace it. they have nubers on the that tell you what kind it is. search the web, you can find the new on ebay check, and you can put it in your self and save time and money.
Posted on Nov 28, 2007
SOURCE:
The Temperature light comes on after replacing bulb.
I am experiencing the exact same problem. hope someone comes on worn a solution. projector worked fine before replacement - all fans have been cleaned and are working properly. ..
Mar 31, 2014 | Mitsubishi HC3800 1080p Home Theater DLP...
Light goes on and off lightware vp800
Hi, How long have you had the unit? If its new take it back and get warranty repair. If longer then, try giving it a good clean. Get some "Air Cans" if you can to blow trough the vents. It could be dust/dirt on the sensor. If you clean it first then we can be sure. If you are ok about taking the casing off then you can give it a better clean. If after cleaning it is still playing up, it is an overheating problem and best repaired by proper service centre as they can get the parts you need.
Sep 08, 2007 | Audio Players & Recorders
Projector starts the goes off by itself.
Check the fan is working could be shutting down cause overheat
Oct 16, 2012 | Sony VPL-ES7 LCD Projector
Changed lamp but when powering up ready light is on and lamp light, and when it powers up it goes to lamp light and never comes on. Any idea what problem is?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 08, 2011 | Sanyo (6102932751) Projector Lamp for...
Infocus LP530 will turn on and work great for 15 minutes then shuts down and the green light turns orange and blinks. The Bulb only has 283 hours on it.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector ro provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
Jul 20, 2010 | InFocus LP 530 Multimedia Projector
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
get a small fan and place it near the projector to provide
Jul 18, 2010 | Dell 3200MP Multimedia Projector
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Lightware vp800
blow out the dust, check the fans, and then replace the thermo sensor if necessary
Sep 08, 2007 | Office Equipment & Supplies
Open Questions:
Computers & Internet Logo
323 people viewed this question
Ekse
Alun Cox
