Question about Epson Stylus CX6600 All-In-One InkJet Printer
Cartridge changing How to move ink cartridges carriage along its slide to be able to lift out used and replace with fresh ink caretridges, please.
  • Anonymous Nov 08, 2007
    how to change ink cartridge and where to go to change it on the printer
    krisdan
  • Azterix Feb 17, 2008
    i have found this printer--epson stylus cx6400--in a luxury building at fifth ave nyc. assumed that it's working, i took it home. But it is missing all the cartridges. Can it work with just a black ink cartridge?
    President:
  • 1,114 Answers
You can download the manual from the link below: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=41664&prodoid=46253282&category=Products Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 03, 2007
SOURCE:
6510 Model. How do I change the in k cartridges
Step one: Open the All-in-One
  1. Press the Power button ( ) to turn on the product, if it
    is not already on.
  2. Open the cartridge-access door. The carriage moves
    to the center of the product. Wait until the carriage stops moving before
    proceeding.
    Figure 1: Open the cartridge-access
    door
Step two: Replace the old cartridge
  1. Press in the tab on the front of the cartridge,
    and then pull it out and up to remove it from its slot.
    Figure 2: Remove the cartridge from its
    slot
    CAUTION:Do not lift the gray latch next to the
    carriage to install the cartridges. Doing so can result in incorrectly seated
    ink cartridges and printing problems. The latch must remain down to correctly
    install the ink cartridges.
  2. On the replacement cartridge, pull the orange
    pull-tab straight back to remove the plastic wrap.
    Figure 3: Remove the plastic wrap
  3. Twist the orange cap counterclockwise to snap it
    off the cartridge.
    Figure 4: Remove the orange cap
  4. With the cartridge contacts facing the printhead,
    slide the cartridge into the correct slot. The color-coded icons on the
    cartridge and in the printhead indicate the correct slot.
    Figure 5: Insert the ink cartridge
  5. Press down on the ink cartridge until it clicks
    firmly into place.
    Figure 6: Press the cartridge into place
  6. Repeat these steps for each cartridge that you want
    to replace.
  7. Close the cartridge access door. The carriage moves
    to the right side of the product.
Aug 19, 2013 | HP Officejet 6500 Wireless All-in-One...
Ink cartridge in Z705 will not move to center of carriage for changing when top is lifted Even though the Belt is moving. Help !!!!!!!!!!!.. >:( :( :'(
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this helps.
Oct 24, 2011 | Lexmark PhotoJet Z705 InkJet Printer
How do I change ink cartridges onEpson Stylus SX425W printer. Apart from lifting the scanner I cant see any buttons to press and the present cartridges wont move along to enable me to eject the black one.
Turn the printer on.
Lift the lid that covers the print-head mechanism.
In a few seconds, the print-heads will slide to a position where the ink-cartridge can be removed.
Then, "unlock" the ink-cartridge from its socket, and gently remove it.
Replace it.
Then, "lock" the ink-cartridge into place, and close the lid.
Print a test-page.
Apr 11, 2011 | Epson Office Equipment & Supplies
How do i change the cartridge
See below: Also is a link the the manual for your unit the maunal has pictures: Page 62 of the manual list the procedure. (page 72 in the adobe file)
Manual
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
Note: It is normal to see ink buildup in the print cartridge slots.
Print-carriage
access door
hp officejet 5500 series
chapter 8
64 maintain your hp officejet
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the pink tape by using the pull
tab.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
Note: You must install both print cartridges in order for your HP Officejet to
work.
reference guide
65
6 Close the print-carriage access door. Within a few minutes, a print
cartridge alignment page prints.
Feb 25, 2011 | HP Officejet 5510 All-In-One Thermal...
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Put new ink in printer. got the message "carriage jam" checked ink to see if correctly installed...it was. tried to use it again and same message appeared. Did as was instructed on Kodak...
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 15, 2010 | Office Equipment & Supplies
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
How do you change an ink cartridge on a HP officejet 5510 printer?
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Aug 11, 2008 | Office Equipment & Supplies
Epson Stylus CX6600 All-In-One InkJet Printer Logo
175 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
