Question about Samsung HT-Z310T Theater System
Surround sound i got the bright idea to hook up more speakers to my surround sound well it sounded good for about 2 min then blew the sound out of the right side ,its not the speakers ,i tried switching them left to right and they work must have blew out card dont have book to show me what part might be blown out please help
  • 2 more comments
  • Anonymous Nov 18, 2007
    need a new sub woofer where will i get 1
  • Anonymous Mar 03, 2008
    no sound only picture
  • Anonymous Oct 02, 2008
    my lg dvd home theater problem is out put of sourround from dvd player i check from my area lg service person came and check he siad so i spare part because i bought in omen so plz replay me as soon as
  • badcream Dec 17, 2008
    model 7500G,,,bought at flea market/no manual/sys turn on(lite on) no sound ...wat now????
  • 3 Answers
Adding more speakers in parallel reduces the impedance, causing the amp to work harder. if you reduce the impedance to much and turn the volume up its a bit like making a short across the output, and has probably damaged the output stage. if you are really lucky it may be fused and simple replacement will fix the issue. if not it could be a costly repair. always observe the minimum impedance rating on your amp and match the speakers to it, never less than it
Posted on Jan 21, 2009
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
I have a new dell inspiron. I just purchased Logitech x-540 surround sound speaker system. The right front, left front, and center speakers don't work. Everything seems to be hooked up right. Any ideas. Is...
Yes there has to be a configuration for the 5.4 surround sound... look if the hardware came with a CD to update the sound driver. or Check if the its correctly configured. on the control panel then click Sound, then depending what windows you have have to lookk for the configuration or properties area and configure as 5.0 or sorround etc.
Feb 21, 2010 | Logitech X-540 Multimedia Surround Sound...
Part of my speakers are just not working. Hooked up, and unhooked and re hooked, but not all speakers working. Right now just 2 of seven are working.
If u have a surround sound card that supports up to the amount of speakers u have (5.1 or 7.1) try change the speaker settings in control pannel as follows.
Start>control pannel>sound>
and see if u have the setting on stereo, if so change it to the 5.1 or 7.1 setting.
If u have software on the otherhand for your sound card you can configure the settings there to change from stereo to surround sound.
Hope this helped :)
Dec 14, 2009 | Logitech X-540 Computer Speakers
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
Apr 24, 2009 | Kenwood VR-407 Receiver
My kenwood surround sounds fuse blew and know theres no sound?
Never bridge a fuse in your life again this is the wrongest thing to do.. Check first there should be IC's skrewed onto a heatsink, some surrounds uses Transistors you should be able to see the burnt ic it will be cracked or burnt, replace that replace fuse if fuse still blow then replace all the ic's on heatsink..
Dec 07, 2008 | Koss KS3102 System
Speaker is not detected
If you are connecting a 5.1 surrround sound rather than 7.1, have you connected the surround speakers to the surround left and surround right rather than surround back left and surround back right?
Nov 11, 2008 | Onkyo TX-SR703 Receiver
Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Dec 31, 2007 | Onkyo HT-S680 System
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
Samsung HT-Z310T Theater System Logo
110 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
