Question about Compaq Presario 2100T Notebook
Clicking in laptop wont boot
I have an older compaq notebook that clicks when you turn it on and won't proceed from the bios options screen
  • slay102 Sep 02, 2007
    Thanks for the info I did some snooping around and also ruled that the hard drive is the colprit
    President:
  • 2,961 Answers
The clicking sound may be a damaged hard drive and the clicking will probably be the parking head trying to park or the platelettes trying to be read. After the bios has done it's initial P.O.S.T.(power on self test) the processor takes over to make the change from bios to processor and then it will look to the drive for the boot.ini to start up windows.
Posted on Sep 02, 2007
SOURCE:
Why is Hp compaq 6710b WI-FI turned off in windows, it is on in boot up but turns off when windows boots switch will not turn it on ?
U probably are missing wifi driver try uninstallung the wifi drivers then restarting the pc so when the pc starts again it will automatically install the correct driver
Aug 28, 2014 | HP Compaq 6710b Notebook
After bios update my laptop wont boot only network boot option is there.
you need to enter the BIOS and configure it. Though there is usually not much to configure in a standard Laptop BIOS. Can you Reload the older one ?
Apr 21, 2014 | Lenovo 3000 Y410 Notebook
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Acer aspire 5349 won't boot
I had the same problem. I clicked on F2. in Bios screen I press f10 (save and exit), and windows started.
Apr 02, 2012 | Acer Aspire 9300-5349 Notebook
I have a compaq evo N620c and am trying to format it with xp. right now it doesnt get past the black screen where it says" We apologize for the inconvenience but windows did not start succesfully" and then...
When you place your Windows XP Disk in the drive, ensure that as the Notebook starts to boot, the words "Press any key to boot from disc ..." is on the screen and then press any key. If you do not get that option choice, go into the Notebooks BIOS and set first boot option to CD or DVD, then try again.
If the system you have on the Notebook is newer than the verion of XP that you trying to install, the Notebook will default to the newer system. A real pain! so make it boot from the CD not the hard drive with the bios settings.
Oct 16, 2010 | Compaq Evo N610C Notebook
Cannot boot up normally the screen stays dark, but clicking esc when powering up and continuing with f1 does work. why?
Sounds as though your drive boot setup isn't right check in BIOS. F1 is the classic "Continue" after problem encounter key. The Esc, allow you to override and continue.
Feb 05, 2010 | HP Compaq Presario 2200 Notebook
Won't boot past the XP screen
go to bios and select boot option first boot cdrom,
i think f12 press then select boot order, if still cant dvd rom or rw, maybe week,
thanks
Oct 09, 2009 | Compaq Presario 700 470024-192 Notebook
Note book freezing after fan change
This is just an easy problem... what you'll have to do is follow this steps
Step 1: If you have manual of your computer it is better.. restart your notebook, press and hold the key to boot in BIOS setup... try pressing this key F1, F2, Delete or F8, because some laptop and notebooks have different method of going to BIOS.. you will know if it is BIOS Configuration because it has a BIOS Settings at the Title of the screen.. now go to Power Management or Power Monitoring.. you can find the Fan option there.. because you change the fan of your notebook, it detects that the Fan that you installed is not standard with the note book.. go to step 2.
Step 2: Now when you find the fan option try to set to ignore the fan RPM and The Voltage that is uses... if there is... then save your settings by pressing F10 key and wait for the notebook to start normally.. if the notebook won't start normally, then go to step 3.
Step 3: In this step you'll have to Start in Safe Mode.Restart your notebook, while booting press the F8 key then a boot menu will show in your screen.. if there is drive selection, choose the hard disk drive.. if none then proceed in selecting the Safe Mode menu.. wait until its done booting your windows in safe mode.. after have complete run in safe mode.. properly restart your notebook by going to Start>Turn Off Computer> Restart, and it will boot in windows normally...
Hope I Can Help
CLCTECH
Nov 23, 2008 | HP Compaq Presario 2200 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Boot up with no operating system
When the system starts, hold the F10 key and go into BIOS and set CD Rom as 1st Boot device (in Boot Order). Because most Compaq's would put the BIOS in a hidden NON-DOS partition on the hard drive, you may have to get an OEM recovery disk for that model. Because there is no BIOS to go to, the machine doesn't know it has a CD, HD or Floppy to go to. A boot floppy/CD is no help. Alternative 1: With another desktop and IDE to Laptop HD connector, FDISK (make active partition and hidden partition [5mb]), Format both, copy the cabs from WinME CD to c:\windows\options. Alternative 2: Find the COMPAQ OEM CD for that model. Since there was no exact model number Click here Please indicate whether this is helpful or not.
Oct 28, 2006 | Compaq Armada 1750 Notebook
Compaq Presario 2100T Notebook Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
