Back to:
Tags:
Receivers
Generic problem for all Receivers
Onkyo TX-28 Receiver Output Problem (by 2 users)
posted by djhack on Sep 02, 2007
I have an unusual problem. I have an Onkyo TX-28 receiver. When I got the unit I connected it up and the right channel put out distorted overdriven audio and the left channel had no audio. I looked inside and the left channel fuse was blown. I replaced the fuse now the right channel has no audio and the left channel puts out the same distorted audio. When I remove the left channel fuse it reverts back to its origial state. Quite a puzzle.
Thanks!
DJ...
Comment by djhack, posted on Sep 04, 2007
No, I am positive it is the speaker fuses. The power fuse is near the power switch.
DJ...
Comment by djhack, posted on Oct 18, 2007
After checking out all the supporting components. I replaced the STK amplifier chip and it works fine now.
DJ...
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Regena, posted on Apr 02, 2008
I have the same problem. Where did you find the STK (power envelope chip)?
Best Solution
posted on Sep 03, 2007
Thanks for Trying (70)
michaelg
Rank:Master Master
Rating: 83%, 24 votes
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Rating Locked! (?) djhack has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Onkyo TX-28 Receiver Output Problem:
I don't want to Accept this solution
Can you Help with these Receivers problems?
Receivers
the pitch control on the DNS 3500 CD deck is telling me...
Receivers
we have a set of jensen spx-11 tower speakers and we have...
Denon AVR-485 6.1 Channels Receiver
I'm trying to play my iPod through the Denon receiver. The...
Receivers
SC-CH150 cassette control not functioning reliably. Will...
Receivers
i need a display for a Harman Kardon AVR30
Loading problems.
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
