SOURCE: hi, have a stihl fs 85, runs fine for 10 minutes, then just cuts out. tried cleaning carb, muffler.
Two things spring to mind, fuel tank breather, to rule this out slacken off the filler cap when the machine starts to die, if it picks up again change the tank breather, or the ignition coil is breaking down when hot, this would require a replacment unit.
Check for an air leak... You pressure check the crankcase.
