Your Acer Aspire, like any other desktop
computer system, contains fans inside the case to help vent the heat generated
by the internal components.
These fans generally operate quietly and
reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could
indicate a problem such as overheating or loose internal components, or it
could simply be a normally loud fan.
The key to differentiating between the two
involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in
some desktops sound louder than others.
Depending on what other brands of computers you've owned or
have had experience with, the fan in the Acer may sound louder, when it's
actually functioning perfectly.
The fan will run to keep the inside of the computer from
overheating, so periodic runs are normal. If the fan runs for long periods or
very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or
to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away
the lubricant coating on the fan's internal shaft, causing the blades to make
excessive noise as they turn. In many cases, a loud fan indicates that the
computer is overheating, causing the fan to run more often than usual to try
and cool the system.
Depending on the types of components and upgrades within
your Acer computer, your current fan may be too small and weak to handle the
heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting
Take note of when the fan turns on and how long it runs to
determine any distinct patterns, whether if it occurs only during certain
processes or programs.
Your computer's CPU generates a large amount of heat while
in operation, so programs that require large amounts of CPU usage may trigger
the fan more often.
Watch for additional signs of overheating, such as sudden
shutdowns or computer crashes. Check inside the case for signs of other
components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive
programs at once.
Check that all screws, cards and wires are securely fastened
and away from the fan.
Keep your computer clean inside and out, to prevent the
build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper
lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
SOURCE: New Acer Aspire E700 does not load-up
Does your BIOS POST runs then you might be having a Disk Booting Problem, If you dont see your BIOS POST Screen, then check if you can hear any beep sounds, If you hear beep sounds check the ram whether it is properly inserted in the ram slot or the ram might be faulty.(You may have to change the Ram). If you dont hear any beep, check whether the buzzer(Speaker in the CPU) is working, If buzzers were working fine before, then you might be having problems with your mother board or processor. If you know how to work on such problem try reinstalling the processor, ram etc in the cpu . Otherwise call a service engineer to have the job done.
SOURCE: taking front panel of an acer aspire e380
please try with acer for spare they might help u with this because the design of model r pc will be different thats better to call acer
SOURCE: Loud fan noise
Some HP computers are known for video card fan noise. I had an a1250n and a m9500f with this problem. On the a1250n, they replaced the video card 4 times. HP finallt told me they know about this problem. I guess they had to keep giving inferior video cards until you got a good one. If it is under warranty get a free replacement from HP. If not, don't mess trying to fix it like putting special oil on the fan spindel which helps for a short while.
SOURCE: Acer Aspire X1301 is excessively loud, runs one speed always.
Are all the vents clear from obstructions, fluff etc?
SOURCE: my acer aspire 5640 doesnot seem to post. I turn
Make sure the memory and any add-on cards are seated properly on the mainboard. If this has no effect try replaceing the cables to the disk drive(s) with new ones. As a last resort you can reset the BIOS either by removing the specified jumper on the mainboard or removing the coin cell battery for 10 mins or so. Good luck.
