Alright so I'm using wireless internet connection. I had to get my computer fixed and when I got back I had to do a few things to connect then I had a nice stable semi fast connection. It's been like a month or 2 and my connection has slowed down to 36mbs which I find ridiculous I used to have 78mbs does anyone one know what to do? The router is pretty new and my laptop is a 4 months old. When I move closer the connection is normal and fast. but when I'm in my room it goes slows down to 36mbs. I don't know whats wrong it used to be fast in my room, whats wrong now? Thanks to those who try and help ;).
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
Try this: turn off your modem for three minuets and unplug your router. Or... go to start settings, network connections, and right clickyour wireless card and select properties. Select TC/IP and make shure both top and bottom sections are on obtain ip adress automaticly. x out of that and press the configure button and select config or advanced. in the ssid type uwpwireless.
Have you simply tried to restart the router and modem by turning it off for few seconds than on again and make sure to turn on modem first then after a few seconds the router. Also, you can try different frequencies your router sends signals by entering the router web access page. The web access page ip address is shown on the back or under side of your router. You may have to directly connect the router to pc to access the router settings page.
A neighbor's connection could very well affect you. That's what I think your problem is. Now, to be honest, a 36mbs connection is pretty darn good. It's rare that an application would require more. Even a video streaming solution will work fine over that kind of connection. My professional opinion is, not to do anything.
Wireless networks have become an increasingly popular way to access the Internet. Connecting to a wireless network allows you to browse the Internet without having to physically connect any cords to your computer.
Troubleshooting wireless connectivity can sometimes be confusing, because even if a wireless network is not able to bring you to any web pages, often your computer's wireless card will still connect to the wireless network that is being broadcast.
In other words, a wireless network will read "connected" even if it is not connected to the Internet.
Connect to a different wireless network. If there is an alternate wireless network within range of your computer that you legally are able to use (a free public Wi-Fi rather than your neighbor's wireless network, for instance), try connecting to it and browsing the Internet.
If the same issue occurs on the alternate wireless network, you may have an issue with your computer's wireless card or with your Internet browser.
If you are able to connect to the alternate network but still not able to connect to your own, the problem is most likely localized to the wireless network you use at home.
Reset all devices.
The great majority of Internet connection issues can be resolved by a simple reset of all the devices in your home network.
Locate the power cords of both your modem and your wireless router and unplug them (if you use a modem/router combination, simply unplug its power cord) for a full 30 seconds.
Plug them back in and restart your computer.
Try to connect to the Internet using your wireless network after your computer has booted back up.
If the connection still fails, some further troubleshooting is required.
Bypass your wireless router.
If your computer's wireless card is connecting to your wireless network of choice yet you are still not able to access any websites, there may be a connection issue on either your modem or router.
The easiest way to locate the problem is to temporarily eliminate the router from the network. Locate the Ethernet cable that connects your modem to your router and unplug it from the router.
Plug the cable directly into one of the Ethernet ports on your computer and reset the modem in the manner described above.
Now try your Internet connection again. If there is still no Internet access, the problem is most likely with your modem or your computer; contact the technical support department of your Internet service provider (ISP) for further assistance.
If the modem goes online directly connected, your router is causing the problem and may need to be reconfigured. Contact the router manufacturer for further assistance.
Hope this helps
None, I thought my house phone may have been interfering but it hadn't in the past but I still moved it because it uses a 5.8ghz frequency. But it didn't seem to have a significant difference.
Yes, there are about 4-5. But this (I dont think) affected my connection before.
What I've noticed though is that the duration wont change it's been 00:12:32 for an hr. And when I disconnected and tryed re-connecting it took a wile. It said cannot connect to access point.
Is there a neighbor's wireless connection that you can see in the "available wireless networks"?
Wireless internet connections sometimes use the same frequencies as phones, and other devices, like like some kitchen devices. Have you purchased and put into place a new phone or other new device?
