Question about Sanyo DVW-5000 DVD Player/VCR
Programming channels I gave my Sanyo VCR/DVD combo to my mother. I cannot find the manual. I tried to program the channels in using "menu" + "channel setup" and also "VCR setup" and it is not working. Can you help me? Thanks for any info you can give. Lynn [email protected]
    Problem Solver:
  • 3 Answers
Press Menu, press up and down arrows to choose the Input Select option then press side arrows to set the channel. Tuner will automatically cycle through all available channels in your area. After the Auto channel search is complete make sure the Channel source is set appropriately (TV or CATV) by pressing up and down arrows and chossing the correct source by pressing the side arrows using the channel setup menu. Press Menu to return to the TV screen. Use CH/TRK arrows or CHANNEL arrows on the front panel to cycle the DVD+VCR through the channels in memory.
Posted on Mar 21, 2008
SOURCE:
Need coeds for sanyo
Hello
Setup code for Sanyo with One for all URC-3021 is
0154
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
Use the Manufacturer's Codes to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
Mar 07, 2011 | One For All URC-3021 Remote Control
Necesito intruciones del este urc-3021bg1 para programar el televisor vizio.
From the Manual:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR, CBL/SAT,or TV). NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3 . Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
For VIZIO TV try one of the following codes: 1758; 0178; 10178; 627; 502
Mar 04, 2011 | One For All URC-3021 Remote Control
I need help to get a code for my sanyo tv and how to set it up.
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Code for sanyo tv is 0154
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
I am trying to program my urc-4220 all for one remote to my tv and dont know how, i have an older zenith tv and need to know the steps to programing it to my tv
2. On the remote control,press a device key once (i.e.,VCR/PVR,DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once. After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
then release SET.
4. Use the Manufacturer’s Codes (starting on page 36) to
Download the full manual for FREE with codes included from http://www.replacementremotes.com/One-For-All-Manuals/Download-FREE-URC4220-MANUAL-OPERATING-MANUAL.html
Aug 11, 2010 | One For All URC4220 Remote Control
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
CBL/SAT,or TV).
then release SET.
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Sanyo dvd/vcr combo
Your universal remote would have seperate selection buttons for VCR and DVD. If you don't have a VCR button, use AUX. Try programming each function seperately - DVD code for your manufactirer on the DVD button and VCR code for your manufacturer on the VCR button.
Sep 12, 2009 | Sanyo DVW-7100A DVD Player/VCR
Samsung BP59-00071B remote wont program Sanyo VCR DVD combo
Try 543. thats what I need to record to my Sanyo VCR via Bell ExpressVu satellite receiver.
Nov 11, 2008 | Televison & Video
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
URC-3021B00
PROGRAMMING DEVICE CONTROL
CBL/SAT,or TV).
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Nov 26, 2007 | One For All URC-3021 Remote Control
Sanyo DVW-5000 DVD Player/VCR Logo
369 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
