Question about IBM Infoprint 1332 Laser Printer
PRINTER NOT PRINTING IN TRAY
THE PRINTER WILL ONLY PRINT MANUALLY BUT NOT FROM THE TRAY
  • 32 Answers
Make sure the green part in the back of the tray is set exactly to the type of paper you are using. For example, make sure that if you are using letter paper, the paper size selector is set exactly on letter. if it already is try to move it off letter, and then line it up correctly again with letter.
Posted on Jul 24, 2009
SOURCE:
How to print double sided on an epsom 580 printer
From what I can see, this printer does not have a duplexer tray. Thus, you must manually print two-sided. To do this you need a print spooler than will support this by printing the even pages, then after you flip the pages and reinsert them, print the odd pages. This works well unless there is a double-feed, because then all pages after that are out of sequence. It is best, when manually printing two-sided copies, to do them in small batches to avoid waste id your printer is prone to skips and double-feeds.
Aug 24, 2014 | Office Equipment & Supplies
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Jun 25, 2009 | HP LaserJet 4700 Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Apr 13, 2009 | HP LaserJet 5000dn Printer
HP 3600dn Duplexing Issue
Manual 2-sided printing. Most of the supported media sizes and types listed for printing from tray 1 can be manually duplexed. Do not use the 2–sided printing feature on transparencies, envelopes, or labels.
I found this note in the 3600 service manual. Maybe it will help.
Mar 06, 2009 | HP LaserJet 3600dn Printer
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
Hp 4350 - Manually feed not printing on its own
from the configuration menu you most select the manual tray and keep it first
Mar 12, 2008 | HP LaserJet 4350 Printer
Printing legal documents
Absolutely. Just click on the "PROPERTIES" button found on the "PRINT"menu. Find the "PAPER SOURCE" option, open it and select "Manual Paper Tray" or "Manual MPT". As soon as you confirm your print job, you unit will display a message asking for paper on the manual tray, which is the horizontal slot just above the paper tray. Insert each legal paper manually until your print job is done.
Oct 30, 2007 | Samsung SCX-4016 Laser Printer
IBM Infoprint 1332 Laser Printer Logo
115 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
