Question about Jwin JD-TV1300 13 in. TV/DVD Combo
Dvd's not playing
Insert a dvd and it says "loading..." forever then says "wrong disc". used to be able to keep opening then closing the drawer and it would finally it wont work at all. some discs play right away, some play after a few tries, and others wont play at all. tried cleaning both disc and player; neither of which work.
  • 1,139 Answers
This might be a problem with the alignment of the actual laser in your device. You mentioned that you cleaned the player? Question, how? The reason I ask is because if you used alcohol and canned air you many have left a residue on the laser facet which would cause such a problem. I would suggest that you use an apporved fiber optic cleaning solution and attempt to clean the laser, (it is best to let a pro do this). Then check the laser alignment and power with a laser power meter.
Posted on Sep 03, 2007
  • kelley2005 Aug 24, 2011
    I am having a similar problem. The cd's play but the dvd's keep making a clicking sound and then say no disc. The dvd's will not work. Please help!
The DVD player keeps opening and closing and won't play/load DVD's. What could be the problem?
There are sensors which tell the DVD drive that the drawer is closed and that there is a DVD inserted, if these fail there is usually no simple fix, the parts need to be replaced which requires complete dis-assesembly of the TV/DVD, Most people just choose to connect an external DVD as it is cheaper.
Mar 07, 2012 | V7 VC2607 26 in. LCD TV/DVD Combo
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Jun 22, 2011 | Sony DVP-C670D
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
When the disc is loading it stops and says
pls. check regnel code seting .
use remote cantrol on setup menu open and selact regnal code set Adealt . or all regnel code after then use disc is play caractly
if not then problum is inside your disc player .
Use. lance clenar disc and clenig your disc player lance.
Oct 20, 2009 | Venturer 3.6" Portable DVD Player
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Can i make it region free?
Turn on your DVD Player
Press OPEN on remote
Press 1 3 7 9 and the number of the region you want to use between 0 and 6. Use 0 for region free. You may need to press these buttons slowly. You will see XXXX on the TV. When you press the last number, it will display at the top left of the screen.
Now insert a disc (other than your own region) into the player and close it. It should load and play. Other region discs should play as well. If you didn't do it correctly it will display "Wrong Region".
When you turn off the DVD player it will keep the settings.
Oct 11, 2009 | Daewoo DVG-9100N
H02 Error after inserting a dvd disk
The trouble started with an error to close and open the DVD drawer. It indicated "close" when the drawer was open, or "no disc" when the DVD was inside, and I had to try many times before I get the right response and go on with the procedures.
But then it also started playing just a few MP3 tracks and stopping to work, showing again the inserted DVD data. Later H02, and then H07 and STOP. It doesn't even start playing stuffs, movies or MP3 tracks!
Aug 11, 2008 | Panasonic Televison & Video
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
Jan 02, 2008 | Koss KD365 DVD Player
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Jwin JD-TV1300 13 in. TV/DVD Combo Logo
136 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
