Question about Lexmark Z600 InkJet Printer
Blinking light -no connection
My Z600 printer has been working fine. However I have recently experiences connection problems. When I turn on the on/off light just blinks. If I try to print something it will show a connection and status shows "Printing" to the printer - but nothing happens.
  • John Nash Dec 11, 2007
    When the printer is turned on, the light continues to flash. I have reinstalled the drivers, I have found upgrades, and I have checked connections for it, I have even replaced the USB cable with another that I know works. When I use the troubleshoot it tells me that there is a bad USB connection.
    This is extremly perplexing as there appears to be no viable solution to the problem.
  • 163 Answers
Reinstall your printer drivers
Posted on Sep 19, 2007
SOURCE:
Carriage slams into left side
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 22, 2013 | Lexmark Z600 InkJet Printer
My lexmark z600 won't install on my wins 7
Following are some of the tips, which you must follow while you are using a printer with Windows 7 system.
Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well.
Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on.
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
Feb 16, 2011 | Lexmark Z600 InkJet Printer
Recently I upgraded my desktop computer with a fater processor of Intel Core i3-530(2.93 GHz., 4MB Cache)and install Windows 7 as its operating system. When I reinstall he driiver of my Lexmark Z600 InkJet...
Yes, you need to go to the Lexmark website and download a win7 driver. At a guess you tried to install a driver for an older operating system.
Go to Lexmark then follow links for support and downloads entering the O/S and printer model as required.
Alternatively, google "Lexmark Z600 driver for windows 7".
Jan 02, 2011 | Lexmark Office Equipment & Supplies
Trying to install my Lexmark Z600 printer on my new Dell Inspiron desktop. It worked fine on my old computer. I have the CD and have installed it and, in the setting up process ticked Lexmark Z600. I...
bordermec is right - If you didnt install it correctly you may have to remove the software and start again.
Although it sounds like you dont have a good connection bet the PC and the printer. Double check that as well.
Oct 30, 2009 | Lexmark Z600 InkJet Printer
Paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
Sep 04, 2009 | Brother HL 5140 Laser Printer
Help with printer!
Does it ask you to print a test page or anything when you installed it?If it does, you needed to do that before you try to print anything else.
Id uninstall it then reinstall and see if that helps. Remove all plugs connecting it to pc and put them back in-that may also solve things.
Jun 20, 2009 | Lexmark Z600 InkJet Printer
PAPER FEEDER SOUND AND LIGHT IS BLINKING
when you turn it on, the ink cartridge holder should be moving left to right (aligning itself). make sure the cartridges are insterted correctly and that the clasps are all the way in.
Jan 10, 2009 | Lexmark Z600 InkJet Printer
Z600 wont print, ribbon error
in the switched at the front of the printer you can configure it to direct thermal mode.. or if you are using printer driver please configure it also to direct thermal mode..
Jul 08, 2008 | Zebra Stripe S600 Thermal Label Printer
Lexmark Z600 InkJet Printer Logo
150 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
