Question about Crosley CE35100AA Electric Kitchen Range
Crosley kitchen range Model CSF 365006 control panel
The control panel does not lght up and there is no response when I press any of the buttoms. Do I have to change the contol panel completly? Thank you
0 characters
1 Points
Kitchenaid model YKGSC308LSO is showing code PF
Press and hold the Start pad for 5 seconds until "Control Lock" appears on the display. Repeat to unlock, and "Control Lock" will disappear from the display.
Apr 19, 2014 | Kitchen Ranges
Coil on stove top will not work properly
I think you will need a replacement heat element control unit, the module behind the knob on the controls panel. Take care if you intend to fit it yourself, make absolutely sure the stove main switch is off or the fuse pulled.
Jan 11, 2014 | Crosley CE35100AA Electric Kitchen Range
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here:
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I need a manual for Crosley Self Cleaning model CSF 36500-1 or instructions on how to use the self cleaning oven.
Go to www.servicemanuals,net recheck your model number i looked for the one you listed and did not find it.
Sep 03, 2009 | Kitchen Ranges
Lost manual for Crosley self cleaning oven-HELP
Copy the below link into your browser and contact Customer Services, they should be able to email one to you for your model
Dec 11, 2008 | Crosley CE35100AA Electric Kitchen Range
Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps! RC
Jun 21, 2008 | Crosley CE35111AA Electric Kitchen Range
Control panel quit
you have somehow gotten the machine into a sabbath mode SAB. consult your user manual to tell how to exit mode.(try holding clock button in for 3-5 secs if not please get me entire model and serial ill research for you
Mar 04, 2008 | Crosley CE35100AA Electric Kitchen Range
Stove manuals for Crosley Electric Stoves
how do I operate the self cleaning function on my stove model
Nov 12, 2007 | Crosley CE35100AA Electric Kitchen Range
Crosley CE35100AA Electric Kitchen Range Logo
Top Crosley Kitchen Ranges Experts
Bruce Bracey
Bruce Bracey
Barrett Palumbo
Barrett Palumbo
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
