Question about Panasonic NN-S950BA Microwave Oven
Too Much Steam?
I was trying to eliminate cooking odor in microwave and put a glass container of water with vinegar in micriwave to boil. The microwave steamed up and stopped working. The keypad is blank and unresponsive. Is there a "circuit breaker type" switch that can be reset? Please Help.
  • Panasonic Master
  • 9,156 Answers
It's possible that the vents got blocked. If it vents to the outside, look for debris in the vent exit at the side or attic of the home. If you're lucky, these will dry put (sometimes it helps to remove the cover) but sometimes the excess moisture gets in and cannot get out. This causes a keypad or control board failure. Please post an update if you still need help.
Posted on Sep 22, 2007
Over cooked something in microwave and now inside is yellow. How can I return it to white?
Once the plastic is yellowed, there's not much you can do to remove the yellow discoloration. Just continue to use your microwave as usual. If a burnt smell remains, you can heat vinegar in the microwave which will help eliminate the horrible odor--like burnt popcorn!!!! Yuck!
May 23, 2016 | Maytag Microwave Ovens
Microwave burn smell how to remove
put an ozone generator inside for 5-10min. Unplug the microwave, then run the ozone generator for 5-10min. IF that does not work you may need to start replacing plastic bits inside.
Mar 02, 2018 | Microwave Ovens
Condensation between door glasses
This moisture can accumulate from certain types of cooking (lots of boiling) in the microwave or in extreme cases, from a blocked grease filter or exhaust vent duct.
Spills or large amounts of accumulated moisture should be wiped off. Minor amounts can dry out by themselves easier if you leave the door open after cooking.
Also, when boiling on the stovetop, you should always use the hood vent exhuast fan to keep steam and grease out of the controls and the door area of the microwave. I always recommend using the vent fan with any cooking on the stovetop.
As long as it is not rusting the metal mesh screen or other parts of the door, it can be allowed to dry out over a period of days with the door open.
If it is a convection microwave, using the convection heat will help it dry.
May 19, 2013 | Microwave Ovens
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    How to get a burnt smell out of mocrowave
    Mix some vinegar in a cup of water, put in microwave and set for 60 seconds, {may need more time} and wait till it starts to steam {may need to repeat} this will bind itself to the interior eliminating the burnt smell.
    May 16, 2012 | Rival Microwave Ovens
    Our new microwave heats the containers but not the food. Container is too hot to touch. Food "looks" hot, usually boiling - but food isn't even warm.
    Check on the material the containers are made of. If they are not microwave friendly then they will cause problems.
    Some materials are designed to "Roast" the contents by absorbing the energy.
    Check with a Pyrex glass container and water. The glass should stay fairly cool.
    Feb 01, 2011 | Whirlpool MH2175XS Microwave Oven
    My 7qt slow cooker glass cover doesn't have a small hole for the steam to escape, so while it's cooking it is continually lifting the cover spitting out water and dripping over the whole counter, is that...
    The slow cooker works by heating the food up to around 85 degrees Celcius and should not boil. If you have it hot enough to boil place a tooth pick under the glass edge. That will let the steam out.
    Jan 13, 2011 | Microwave Ovens
    I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
    Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
    Jan 08, 2011 | GE JES1384SF Microwave Oven
    Food left in the oven has left a smell even after thorough cleaning.what action should i take
    Have you tried putting a microwaveable bowl with a mixture of water ,vinegar and some slices of lemons or oranges in your micro for about 2 minutes. It should help eliminate the bad odors and leave your microwave smelling freah and clean.
    Nov 10, 2010 | Panasonic NN-H965 Microwave Oven
    Boiling water
    This is not unusual, and it can reuslt in a nasty burn.
    It may help if you be sure the sides of the container are wet before you heat it.
    Also, after heating, if you push the microwave back and forth a little bit before opening the door, that may trigger the outburst in a safer manner.
    Even better, if this happens a lot with a certain container, put a wooden (non-metallic) spoon in the container before you heat it.
    Here's an interesting article about this from Snopes:
    http://www.snopes.com/science/microwave.asp
    And an advisory from the FDA:
    http://www.fda.gov/cdrh/consumer/erupted.html
    Nov 18, 2007 | Microwave Ovens
    Panasonic NN-S950BA Microwave Oven Logo
    222 people viewed this question
    Top Panasonic Microwave Ovens Experts
    William Miller
    William Miller
    Steve Allison
    Steve Allison
    Jaime Hernandez
    Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
