Question about Denon AVR-1507 Receiver
2 zone setup
I would like to watch and listen to tv on zone 1 while listening to the tuner on zone 2. Right now when I switch to zone 2 the TV picture stays on, but the front speakers and the outdoor speakers play the tuner. I would like only th eoutdoor speakers to play the tuner and the front speakers to retain the tv sound.
  • Butch1958 Mar 07, 2008
    I have the same issue.Cannot find the solution in the manual.
  • Anonymous Mar 30, 2014
    Suddenly the TV has no picture but has sound. When I move the cables from monitor to zone 2 everything is ok
    Problem Solver:
  • 20 Answers
Consult the user manual. If you don't have one, it can be downloaded free at Denon's website. Two of the speaker oututs serve multiple functions. Hookup and setup need to be checked. What you want to do is possible as long as you're only using a 5.1 setup indoors.
Posted on Sep 19, 2007
How to hook up the TV
To use the TV as a Monitor: Use an HDMI cable from the Monitor Out on the 6006 to an HDMI Input on the TV. You need to go into the setup menu and set the HDMI sound to go to the amp and not the TV.
If you are tuning TV stations with an antenna and the TV tuner: First connect the TV as above so you can watch your other sources, like Blu-ray players. Then add an Optical Digital Audio cable from the output on the TV to an optical input on the TV. When watching antenna TV, select the input on the 6006 that the optical cable is connected to. You may have to play with settings in the TV and the 6006 to get this to work! You should be able to listen to 5.1 sound while watching tv over the antenna.
Mar 08, 2015 | Marantz SR6006
How to use tv split screen
If your TV has picture-by-picture and you have both a TV aerial/antenna and another form of tuner (Satellite box, cable TV receiver etc then you can do it.
Otherwise you'll need a split screen device and two external tuners. That'll be expensive. It would be cheaper to buy another TV.
Sep 05, 2014 | Televison & Video
When listening to bose 321 system what should the volume of the tv be set at?
OFF. Unless the TV is the original source of what you're watching (antenna). Otherwise, your programming is probably coming from a cable/sat box with all the digital audio goodies, right?
If your TV has a menu for setting the volume out its RCA connections I would recommend you set it to whatever resembles FIXED, so it's volume control won't kill the stereo analog audio going out to the Bose. Then you can turn it off at the TV and listen through the Bose.
For the best multichannel audio you should get it digitally from the original source you're watching on the TV, but NOT from the TV itself.
Jul 17, 2010 | Bose 3 2 1 GSX System
The sound stopped working on my koss KS2503. Yesterday everything worked perfectly fine. Today there is no sound. Everything else seems to work. I checked all the connections and have had no success. Is...
unplugg your tuner from the AC wall outlet then check the setting on the tuner do not try to watch and listen to the tv only try to listen to the radio or a CD and select the right option on the tuner to do so. If you have sound on any of the functions....radio or CD/MP3 then the problem lies on the setting not correct for the TV/VCR/DVD mode.
Sep 12, 2009 | Koss KS2503 System
NO sound on TV Picture fine, sound when watching DVD
check your scart male connecter ends are pushed all the way in.
Jan 15, 2009 | LG 52SX4D 52" HDTV
Problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
Dec 26, 2008 | Samsung 1000W 5.1-Ch. Home Theater System...
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
Denon 4308
ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Jun 01, 2008 | Denon AVR-4308CI Receiver
Denon AVR-1507 Receiver Logo
285 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
