Question about Nikon COOLPIX L3 Digital Camera
Camera will not power on
Coolpix l3 will not power on or do anything, it is less than 1 yr old and of course the batteries are new.
  • 3 Answers
Try using lithium batteries...If that doesn't work then send it to Nikon with a letter. The letter should include the following: Name, address, where you got the camera from, when you got the camera. No need for a box or receipt, just be sure to include a letter. Good luck
Posted on Nov 16, 2007
    Problem Solver:
  • 10 Answers
Your camera is still covered by nikon warranty you need to send to them for warranty work.
Posted on Sep 14, 2007
Lens error for coolpix l3. The lens won't retract and the camera won't work. took batteries out and put new ones in. nothing is working. is there a way to reset the camera?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 29, 2011 | Nikon COOLPIX L3 Digital Camera
Describe your COOLPIX L3 Digital Camera Problem I keep getting Lens Error message, what should I do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 31, 2011 | Nikon COOLPIX L3 Digital Camera
After my Nicon coolpix S570 has dropped on the floor, the lens does not work and when i turn on the camera, i hear a noise and get a message for lense error.
you have stripped the lens gearing you will find that you need to have the lens gogs replaced a very expensive repair sir. it may be time to buy a new one
sorry
take care
may you and yours have a happy new yr
Dec 29, 2010 | Nikon COOLPIX L3 Digital Camera
My Nikon coolpix L3 appeared LENS ERROR how do i solve this fault
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 13, 2010 | Nikon COOLPIX L3 Digital Camera
Batteries Exhausted Message on Nikon Coolpix L18
How could I resist assisting someone with the handle 'Charm City'? What I would advise is getting some good quality 2300 mAH or 2500 mAh re-chargeable batteries - although all batteries have a nominal 1.5v output, not all can provide the sustained power necessary for the camera.
Aug 19, 2017 | Nikon COOLPIX L3 Digital Camera
My Nikon Coolpix L3 camera won't power up. I've checked the batteries and they're okay. I've tried connecting it to the PC with the USB cable, but still nothing. The last time I used it was about 6 weeks...
This camera will not run from the usb. It needs batteries or an adapter. Some small digital blister pack kind of cameras can run from the usb power from the computer or other source.
Make sure you have full charged batteries.
Take the batteries out, and check for corrosion inside the battery compartment. If any is there, clean and try again.
Take care,
Jun 29, 2008 | Nikon COOLPIX L3 Digital Camera
Two cameras and two lens erros
I don't think either camera is worth the over $100.00 that it will cost to fix. However, look at my posts on this problem of lens errors. By forcing gently the lens in or out when you start the camera and shut it off, it may get the lens to work again.
This may damage the camera even further, up to you, and may be worth a try.
Apr 11, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix L3 thinks batteries are dead
I think this was a firmware fault on some cameras. Check with Nikon to see if there is a new firmware for your particular camera. This can be downloaded free of charge and uploaded to the camera via USB.
Jan 04, 2008 | Nikon COOLPIX L3 Digital Camera
Batteries die
Hello; Same as tbeartusk on my coolpix L3 Nikon
Batts exhausted within 30 Min. and screen says Batteries "exhausted"
Nov 12, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
64 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
