Question about Fisher and Paykel GWL11 Top Load Washer
Fisher paykal top load washing machine
My washing machine won't finish the spin cycle. It will start the spin cycle but before it is done spinning I will hear a lot of little beeps and the lid lock light is on but the spin cycle is not finished.
  • 1 more comment
  • gunner 2 Jul 27, 2008
    My Fisher Paykel will not finish the spin cycle; it stops and starts beeping; when I re start it, the same thing happens over and over again.
  • Anonymous Mar 18, 2014
    Overloaded washing machine and now it will not finish the cycle and is stuck on wash mode but will not go into spin mode
  • Anonymous Mar 24, 2014
    wash cycle longer than indicated, hangs at times, does not spin and wash correctly
  • 30 Answers
I would say the load is going out of balance.
Let me know what lights are beeping when it faults out.
Adjust the feet of the washing machine.Only adjust the back two feet buy 15mm. They are on the base of the washing machine.
Posted on Aug 05, 2008
  • 3 Answers
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Posted on Oct 14, 2007
SOURCE:
Washing machine doesn't finish a cycle. No spinning to release water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water would not drain and was slow to spin
Hi Rick.Now on the [email protected] machines they will not spin properly unless all the water is out of your machine.Please look underneath the machine for me and you should see the pump which has a fan attached to it .It is located to the front right.Now turn the fan clockwise and anticlockwise a few times to loosen the pump as it may be jammed.The fan should freely.To look under the machine 1st you must bail some of the water out by hand with a small bucket or pot,enough to lean the machine back so you can look under the machine without it leaking everywhere.Now once the fan turns freely put it back on its feet and select a spin cycle and push the start button.Hopefully the machine will start to drain and spin.Please reply back on how you got on or if the machine still does not drain.
Aug 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
Feb 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
361 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
