Question about HHP 3800 (015305) Handheld
Problem with scanner
I'm trying to set up my quickbooks Pos system. The IT3800 seems to be working in every way accept that when I scan a barcode and it beeps but no numbers show up it the information field.
  • Anonymous Jan 06, 2008
    same problem, connected by usb, sees it as a keyboard ok, beeps when scanning but nothing appears on screen
I have it connected to keyboard port as they instructed.
Posted on Sep 07, 2007
  • 4 Answers
The IT3800 supports many different modes of connecting to a PC. Changing the physical cable connection does not change the mode the scanner is trying to use.
This "mode" is referred to as the Interface. Out of the box, the scanner may not be configured with the Interface that you need to use with the cable that you purchased (unless your reseller made sure this was done).
Scanning the correct Interface programming bar code will configure the scanner to communicate correctly for your cable/connection. The product Quick Start manual contains the most common Interfaces:
http://www.handheld.com/download.aspx?download=/data/f9e7f996-9ecc-4f49-b604-32fbd754085d.pdf&filename=3800+Linear+Series+Quick+Start
Posted on Mar 06, 2008
  • rfmarinho_06
    rfmarinho_06 Jan 28, 2012
    The link above doesn't seem to work anymore. Here is an alternative link:http://www.geoti.co.kr/DATA/hhp/IT3800_3...
  • 661 Answers
Barcode scanners beep to tell you that they have scanned a valid barcode (nothing else). they will operate simply with power...the fact that it will scan a barcode does not mean that it is connected properly. how do you have this connected?
SOURCE:
IT3800 keeps disabling my keyboard, also won't scan into the field
What operating system is running on the Dell PC? What version of the IT3800 User Guide are you using? With answers to these questions I might be able to assist you further.
Aug 26, 2014 | HHP IT3800 Handheld
I have an IT3800 scanner and use it in a gift shop. My products have "regular" barcodes, those with 5 digits added and ISBN barcodes. My scanner stopped scanning the extra 5 digits. I went to the IT3800...
What you need is to turn on Digit Addenda for the types of barcode you are trying to scan. Here is the user's guide:
http://www.geoti.co.kr/DATA/hhp/IT3800_3900%20Users%20Guide.pdf
Please check page 7-30, where you will find the codes to turn on the supplements for EAN 13 barcodes (those with 13-digit). Also, if you don't want the scanner to insert a space between the main code and the additional digits, you have to turn off addenda separator (page 7-31)
There are similar configuration codes for other symbologies (like UPC A) throughout the manual.
Hope it helps!
best regards!
Rafael
Sep 01, 2010 | HHP IT3800 Handheld
Programming the scanner for Quickbooks POS 8.0
You need to program this scanner, I can provide any manuals you need. You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Aug 21, 2009 | HHP IT3800 Handheld
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
Need to have the scanner advance down one space after each scan
What is the exact model of your scanner. I believe it is indicated on the manual that came with it.
Jan 05, 2009 | Symbol LS2208-1AZU0300S Handheld
HHP Handheld IT3800lr-12 - i can't configure it to USB
If you have the manual, try to cofigure it to USB Keyboard and/or to LAPTOP DIRECT CONNECT. This last option is on page 1-7 in the manual I have with me. Please let me know if it works... Good luck!
Dec 15, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
It3800 barcode scanner problems
Will it scan data into excel or word?
May 21, 2007 | HHP IT3800 Handheld
HHP 3800 (015305) Handheld Logo
582 people viewed this question
Top HHP Computers & Internet Experts
Marvin
Marvin
Ekse
gggg
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
