My ipod froze, so I plugged it in then got a lighted up black screen, tried holding the middle button and the play button together, but no luck........HELP!!!!
turn the hold switch on, then off. then hold down the "Play Button" and the "Middle Button" at the same time, until you see the apple logo on the screen. :)
Start by reseting it, hold down the "Menu" button and middle button for about 7-8 seconds. This will most likely work, if it doesn't, try restoring it. Do this by first plugging your iPod into your computer and starting iTunes. Then select your iPod in the list to the left, now click the "Restore" button located under the large picture of your iPod model. Restoring will probably take a little while, maybe 10-15 minutes.
Hi if your ipod froze, just hold down the middle button for one second.. still holding it, press and hold the menubutton for 6 to 10 seconds. then the screen should turn black and after a few seconds a white apple should appear and the i-pod will restart and go back to normal. please rate my suggestion...
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Select buttons
until the Apple logo appears, about 6 to 10 seconds. You may need to
repeat this step.
Tip:
If you are having difficulty resetting your iPod, set
it on a flat surface. Make sure the finger pressing the Select button
is not touching any part of the click wheel. Also make sure that you
are pressing the Menu button toward the outside of the click wheel, and
not near the center.
If the above steps did not work, try connecting
iPod to a power adapter and plug the power adapter into an electrical
outlet, or connect iPod to your computer. Make sure the computer is
turned on and isn't set to go to sleep.
wat you can do, it will most likely work, hold menu and select button for about 8 seconds, then the screen will go black, then boot up with the apple logo
