Question about Sony Cyber-Shot DSC-P72 Digital Camera
Camera does not flash
The flash does not work.. Error message is E:91:01 with a flashing flash sign. Thanks
  • 3 more comments
  • Yogania Sep 03, 2007
    How can I fix this problem??
  • electrigirl Dec 16, 2007
    I have the same problem. What is the solution? Please help.
  • Princess75 Dec 21, 2007
    I am experiencing the same problem with my camera, I had taken several picturs requiring the flash when after the 3 pic this error message appeared and the flash stopped working. I have read the solution but I apologize for my ignorance but I do not understand what it is I need to do to fix this. Could this be clarified a bit more as to what it is I should do to correct this problem with my camera. Thank you!
  • jen01a Feb 24, 2008
    i have the same problem - the flashing "flash" sign and the E:91:01 error message, the lense also seems to be getting stuck when it goes in and out.
    thanks - jenny
  • Anonymous Oct 24, 2008
    I have this problem too. Reset didn't work. There are no more suggestions in the operating instructions. Jan
I reset my camera and the error message has gone, but still won't flash .... still working on it....
Posted on Feb 24, 2008
  • 625 Answers
Problem is with the high voltage capacitor charge circuit. the internal battery voltage is stepped up to around 4 thouseand volts. this voltage is necessary to jump the electrode gap inside the xenon strobe tube which is the flash component
Posted on Sep 02, 2007
Flash error message
Hi What kind of error message flashing? Would you tell how your camera problem like? thanks and best regard!
May 26, 2011 | Sony Cyber-Shot DSC-W530 Digital Camera
I have a camera sony cybershot DSC-W350 and flash is not working. And I receive an error message E:91 01. What do I do?
Hi. Thanks for your question.
To get your camera back in working order you need to reset it to factory settings. Please click on the link below for a video from Sony website on how to perform reset.
http://esupport.sony.com/perl/tutorial-display.pl?tut_id=374&mdl=DSCW50
Thank You for using FixYa.
Jan 14, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Flash won`t work
Error ( E:91:01) is off COMPLETE FLASH UNIT which contains part No. along with description is given below:
A-1166-208-A ST-133 BOARD, COMPLETE
(For DSC-W50)
A-1231-877-A ST-133 BOARD, COMPLETE
(For DSC-W55)
For your convenience please see the pic below of required part:
7985bce.jpg Thanks
May 30, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
What does E:91:01 mean? I get the error message when I turn my camera on and the flash will NOT work. Please help. Thanks,
e:91 is the purticullar flash failer error itmeans you may chang flash unit please go to your nearst sony service centre & fix your problum
Oct 08, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jan 09, 2009 | Sony Handycam DCR-TRV240E Digital...
E91:01 Constant flash sign on Cybershot DSC-W80
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Oct 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash Error
The error 5 can mean that there is something blocking the flash from popping up. If it is up but still get the message then you need to check to see if the little black pin/stick that lets the camera know that the flash is up, is not stuck. With the flash up and pointed at you ( like you are going to take a picture of yourself) the pin is located on the right side close to the where the flash attaches to the camera. Yo should see a little pin sticking up. make sure that area is free of dust and /or debris. if it is not up then that is the problem. try to free it with out braking it or get it professionally repaired.
Jul 08, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Flash wont work
This error is shown when the camera can not charge the flash compasitor in the camera it can be fixed with a new flash circuit.
Mar 07, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
DSCH9
Guys - I just recevied a new H9 today. Was using it and decided to turn the flash off. Later on I wanted to turn it back on and I got the famous "flash settings cannot be changed" error message. I found the problem. I had turned on the "continuous shooting" option as I wanted to see how fast it would take photos continuously. When that option is on, you cannot use the flash so therefore you cannot change the flash settings. I put the camera back in "single-shot" mode and now the flash works fine. I hope this fixes your issue.
Thanks, Ken
Nov 23, 2007 | Sony Cyber-shot DSC-H9 Digital Camera
Sony Cyber-Shot DSC-P72 Digital Camera Logo
73 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
