Maytag top load washer leak
I have a maytag top load washer, about 15 years old. Once the washer fills, water still drips from the fill slot through all cycles, including the spin cycle. Even when the washer is turned off, it still drips.
  • Anonymous Mar 16, 2014
    Maytag top loading washer won't spin
  • 291 Answers
You have a bad water valve.. replace the valve where the hoses are hooked to your washer
Posted on Sep 02, 2007
  • 148 Answers
Above solution is WRONG.  The valve "where the hoses are hooked up to your washer" is a service valve and is part of your house!
The valve that's bad here (and it's probably just a rubber washer) is inside the washer, and is electrically controlled via solenoid.
If you are handy, you can replace it yourself.  You'll need to go to a place like Marcone and order the correct replacement part.
Posted on Jul 08, 2009
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
I have a Maytag A612 I purchased in 1986. I just found a water leak when it fills on the "warm wash' water setting. It does not leak on either the "hot" or "cold" wash water...
Your about right....and getting parts for a 1986 Maytag may be almost impossible. Maytag was sold many years ago and old parts were dumped.
Jan 31, 2018 | Maytag SAV4655A Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag washer, once it is finished washing and spinning and stops running, water keeps dripping into the washer. Why? In a day or so it will almost fill up with water.
First turn the water off at the wall. You have a bad mixing valve.
Write down your model number and then do a google search for Maytag parts. I like Partselect.com and Repairclinic.com both are reputable sites.
Dec 30, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Washer (approx. 7 years old) has slow stream when filling
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I HAVE WATER DRIPPING INTO THE TUB FROM THE RINSE SPROCKETT
hot or cold? the water inlet valve may be cracked or lose...not that hard if you are a handy person!
Dec 05, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Sep 02, 2007 | Washing Machines
Washing Machines Logo
521 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
