Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Camcorder dew light comes on and it ejects the tape constantly,have taken the back up battery out but that doesn't work can you help
  • wayne harris Sep 06, 2007
    brilliant thankyou
Keep your camera 'ON'for more than 1hr.& cover it with black cloth & keep it in the dry room. regards; shailesh
Posted on Sep 03, 2007
SOURCE:
The camera will not load a tape. Without a tape installed the loading mechanism works as it should. when a tape is placed in the camera it does not retract into the camera but opens back up as if to eject...
Symptom shows Dew sensor is activated and most probably you will see water-drop yellow sign flashing in LCD.
Remove battery / power source from camcorder and leave it for 1-2 hours, reattach battery/ power to camera and turn it on and check.
Thanks.
Nov 05, 2009 | Sony Hi8 CCD-TRV138 Camcorder
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
Jul 12, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
GL2 - Tape gets jammed everytime. Eject lights up immediately
This problem is usually related to the Dew Sensor, Unfortunately you can not by-pass the dew sensor. I paid a repair to fix, but he could not. Canon must repair the dew sensor.
I have same prob. I just capture directly to computer since my tape will not open. I would be interested in buying cameras like this, i can use them to still monitor images.
[email protected]
Jul 06, 2009 | Canon GL2 Mini DV Digital Camcorder
"Dew" sitting on my Video Camera
Dew Formation
What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
When dew forms in your camcorder.
Dew will gradually form on the head drum
of your camcorder and make the video
tape stick to the head. This causes
damage both to the head and the tape.
When dew forms, recording and playback
may not function properly.
Dew is likely to form in the following
circumstances:
—When moving the camcorder from a
cold place to a warm place.
—When placing the camcorder in a cold
room which is then heated rapidly.
—When moving the camcorder outdoors
from an air conditioned room or car.
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
“Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
leave the cassette compartment open,
and wait for a few hours to allow the
camcorder to acclimate to the
surrounding temperature.
2To use the camcorder again, turn on the
power after waiting for a few hours. Be
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
flashing; this may result in damage to
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
Mar 13, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Dew detected
Leave the camcorder turned off in a place with constant dry temperature with the door open. Take the battery off and wait a few hours like at least 3.
This should work unless it is really damp inside then it may take longer. This happens when the camera is moved from heat to cold or cold to hot temperature. Both tape and camera need to be climatized to prevent this from happening.
Oct 03, 2008 | Quasar VM-L459 Camcorder
DEW DETECTED / EJECT TAPE
I know that this sounds odd but the fix is to remove the battery and hit the camcorder on the back (where the battery was) with the palm or your hand. Put the batter back and it will work. I found this soluation a a CNET web site solution. I don't know why it works.
Jun 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
"DEW"
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 05, 2008 | E.Digital Sharp VL-Z7E Digital Viewcam...
Dew detected eject tape
I have the same problem with my PV-DV103. Panasonic wants more to TRY and fix it than the camera cost new. MY advise can the camera and buy one without the DEW option.
Thats what I am searching for presently . If the manufacturer says the camera has a dew indicator in the circuit - buy elseware.
Nov 13, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Closing itself down DEW
camcorder when turned on flashes in red DEW and closes it self down. i have taken all the batteries out and replaced sometimes after a few days the camcorder will work then DEW will rea ppear and shut itself down
Nov 02, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Dew light
Dew is likely to form in the following circumstances: ?When moving the camcorder from a cold place to a warm place. ?When placing the camcorder in a cold room which is then heated rapidly. ?When moving the camcorder outdoors from an air conditioned room or car. ?When placing the camcorder in the direct path of air blowing from an air conditioner. ?When placing the camcorder in a humid room. Dew will gradually form on the head drum of your camcorder and make the video tape stick to the head. This causes damage both to the head and the tape. When dew forms, recording and playback may not function properly. When ?DEW? flashes, remove the cassette,leave the cassette compartment open,and wait for a few hours to allow the camcorder to acclimatise to the surrounding temperature. To use the camcorder again, turn on the power after waiting for a few hours. Be sure that ?DEW? has disappeared. Do not insert a cassette while ?DEW? is flashing; this may result in damage to the tape.
Aug 03, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
111 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
