Question about Motorola Mobility SLVR L7 Cellular Phone
When a ringtone is bluetoothed to me, it shows file is corrupt
First of all, when i try to delete one of my ringtones,it goes back to menu screen &doesn't let me delete any ringtones. then when someone bluetooths me a ringtone, it says file is corrupt.
  • 63 Answers
You need to do a master clear on your phone ... you would loose ur pictures and any downloaded stuff, but your wouldn't get that file corrupt error again. Somehow your software probably got a glitch.Try the master clear or the master reset in settings and hopefully as i said this would clear the problem. You can then go ahead and try to bluetooth any files your want to. Sam !
Posted on Sep 02, 2007
SOURCE:
Jvc Kd-s79bt
This answer is found on page 16 of manual. goto BT mode and Press and hold [MENU]. Select
[BLUETOOTH]->
[DELETE PAIR]->[PHONE NAME]-> [DELETE YES]->DELETED!
Jul 02, 2014 | JVC AM FM CD DET FACE CAR STEREO
MOTOROLA i880
turn on bluetooth on both devices.
search for new devices
pair both devices
select files -> send via bluetooth
select the device and press ok
May 14, 2008 | Motorola Mobility i880 Cellular Phone
Android xperia guide
  • Press the center button on your X10 Mini Pro to launch the phone's main menu. Tap on the "Settings" option to enter the Settings menu.
  • 2Tap on the "Wireless Controls" heading to manage your phone's wireless connections. Tap on the "Wi-fi" or "Bluetooth" heading to enable your phone's Wi-Fi or Bluetooth radio.
  • 3Tap the "Wi-Fi Settings" option, and then tap "Add" to connect to a wireless network. Or tap the "Bluetooth" settings and then "Discoverable" to begin pairing your phone with a Bluetooth device. Press the phone's right button to return to the main menu.
  • 4Tap on the "Sounds and Display" option. Tap on the "Silent Mode" option to mute your phone's ring or tap the "Phone Vibrate" option to set your phone to vibrate. Tap on the "Phone Ringtone" option to select a ringtone for your phone.
  • 5Tap on the "Brightness" option to adjust the amount of light your X10 Mini Pro's display will emit. Tap "Screen Timeout" to set the amount of time your phone's display will stay lit after being inactive. Press the phone's right button to return to the main menu.
  • 6Tap on the "Applications" heading. Tap on the "Manage Applications" option to manage the programs that appears in your X10 Mini Pro's main menu. Tap on a program, and then select the "Delete" option to remove the program from your phone. To add a new program, tap on the "Market" icon in the main m
    sincerely. G-d bless you
    ernesto cuadra
    managua,nicaragua.c.a
  • Dec 18, 2011 | Sony Ericsson Cell Phones
    I just bought a used blackberry rim and im haveing problems getting it to allow me to bluetooth any pictures or ringtones..please help
    For any 2nd hand BlackBerry, you have to format you device and configure newly ,.
    for enable blue tooth,
    Or follow the below instruction
    Screen menu> manage connection> check mark on <blue tooth>
    Save
    sedngi via blue tooth ,
    open any picture or ringtone and press the menu button > send using blue tooth”
    receiving via blue tooth ,
    Screen menu > media> press the menu button ,”Receiving using blue tooth”
    Jul 17, 2010 | RIM BlackBerry 7290
    When ringing someone the phone doesn't ring out. the other person can hear me but i cant hear them for a few seconds can you help me please.
    Try to see if you have a connection to a bluetooth, also make sure you arent connected to any other device, especially if you used a cord to retrive photos or d/l ringtones Allows you to set the Bluetooth® power On/Off.
    1. Open the flip, then press [MENU] bluetooth menu options, turn on or off
    2 try menu settings and tools, call settings,pc connections, usb, no connection
    Nov 24, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
    Bluetooth for ringtones
    instead of bluetoothing them use your beam option just go to the main menue and click on the menue key (it is a button) them go to beam that should work
    Nov 15, 2008 | Palm Treo 650 Handheld
    Bluetoothing ringtones
    try a master reset or delete your bluetooth devices that is already in the list..then try again
    Apr 14, 2008 | Motorola Mobility RAZR V3
    Problem
    1. Press Menu
    2. Scroll to and Select Messages
    3. Scroll to and Select Create
    4. Scroll to and Select SMS/EMS or MMS or MMS Templates
    5. Scroll to and Select Insert
    6. Scroll to and Select Sound
    The ringtone download is through EMS or MMS. When you receive the EMS and MMS from another party, you can retrieve the ringtone from an EMS or MMS message. You can also send the ringtone by sending an EMS or MMS.
    Dec 12, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
    Cannot delete ringtones
    HI Below is the step by step method of how to delete your ringtones in your Motorola V3: Here is an easier way to delete the ringtones without much hassle. 1) Upload 1 mp3 rintone to your phone via MPT 2) Set ALL ringtones msg, alert etc, absolutely everything for all styles (obviously excl. silent & vibe) to the uploaded MP3 3) switch your phone off, then on again. This will update the .db files. 4) Using P2K, delete all the rintones, except for the MP3 that you uploaded, do not delete the .db files. Also, do not delete the .bas files as these are the base files for Motomixer. Set all reminders to OFF. do not EVER delete a ringtone that is currently in use by the phone. If you delete it while it is active, You will NOT be able to get into that particular tone setting. 5) Switch your phone off, then on again.
    May 01, 2007 | Motorola Mobility RAZR V3
    Cingular V3 will not add or delete any ringtone
    Okay this happen to my phone a while back and chances are it might happen again. but here is what you do. You need to save all of your contacts to your SIM or smart card, after you do that you need to sit with someone and decide the picture, videos, and ringtones that you want. After you have all of this decided you ne to bluetooth this to a friend who is paitent and willing to help. Once you have all the transfers done you need to do a master clear on the phone, (the reset) doen't work. This will delete everything on your phone including the problem. all that is left for you to do is send the pictures and all the other stuff back to your phone. If you have alot of ringtones I suggest you don't upload those. Motorola doesn't have an answer for this problem but more and more people are experinceing this. Good luck. if this works let me know at [email protected]
    Feb 17, 2007 | Motorola Mobility RAZR V3
    Motorola Mobility SLVR L7 Cellular Phone Logo
    144 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    D. E. Hev
    vince
    Lawrence Oravetz
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
