Question about HP LaserJet 3330MFP All-In-One Printer
Wireless printing Printer is installed on my desktop as a local printer. I have a dlink wireless router and a laptop as the network. How do I set up the printer so I can add it to the laptop and print wirelessly to the printer? I tried to add printer but the printer does not show up
The following assumes you are running MS Windows. It mostly is based on XP, and different versions will surely not be exactly the same, since it IS Microsoft. In any case, there are more details and tools, such as Wizards, in the Help And Support Center (see below) which you should refer to.
First, the laptop and the desktop both must have the same Workgroup name, which is set in System Properties. (Via System in the Control Panel, or right-click on My Computer and choose Properties.) Of course, their Computer Names must be different. Also, remove any Computer Descriptions, since this is known to cause problems - especially when mixing different versions of Windows.
Second, you need to turn on File And Printer Sharing on the desktop PC. This may already be turned on, but if not, you may be prompted to do this, maybe by using the Network Setup Wizard, when you try to Share the printer.
Third, you need to Share the specific printer. In Printers And Faxes (via the Control Panel) right-click on the printer and then left-click on Sharing in the pop-up menu. There you can choose to share the printer and give it a name for the network. If it chokes here, you may need to turn on Sharing as mentioned above.
If the laptop and desktop are different Windows versions, then drivers for both versions may need to be installed. The printer Sharing window may help with that. If not, refer to Help And Support, which should be available by clicking on Start. In some versions of Windows you may need to search within Help for a key word such as print or network. Or, you may need to dig into a menu of topics.
If you used the Network Setup Wizard for any of the above steps, it probably set the Windows Firewall settings ok, but if you are using a third-party firewall, you may need to change some settings there to allow the connection to be made.
Of course, with the printer connected to the desktop, the desktop needs to be turned on in order to print from the laptop. Another option is to get a small print server and connect the printer through it to a port on the router. That way, the laptop could print even when the desktop PC was off. The whole Sharing setup described above would not be needed, although you might do it anyway, in order to share files between the computers. This might also allow (or force) the printer to be moved to a more (or less) convenient location.
Before getting a print server for a multi-function printer, try to confirm with the server maker that it is known to work with that model of printer, or at least with similar units of the same brand. Some of the mfp's have problems if they aren't connected directly to a PC. Getting the latest drivers could help with that.
Whether shared through another PC or directly through the network, the new printer needs to be Added in the Printers And Faxes window. In Printers And Faxes (via the Control Panel) click on Add a Printer, either in the column on the left (if you have it) or in the File menu. You should be able to choose to add a network printer, then browse the network to select it. If you don't find it there, look in My Network Places for clues. For example, make a folder on the desktop PC called Test, then share it, and make a file in it called test.txt, then see if those show up in My Network Places.
As you can see, there are lots of places where it could be broken, but this outline should at least help you to know what sorts of things to look for.
Posted on Jan 26, 2008
SOURCE:
I just want to set up an internal network with dlink router
To setup a network just follow the step by step guide that came with the DIR-615 router. When it comes to setting up the internet on the router wizard just select Cable or DHCP and leave the other internet settings as default.
As regards to your printer we need to know the make and model number so we could further assist you. By knowing the make and model of the printer it will help us how to best setup your printer on the network. The model number is usually the name of the printer or near barcodes on the back or bottom of the printer.
Dec 17, 2012 | D-Link DIR-615 Wireless Router
Installing dlink password into printer
The encryption password is in the D-Link's wireless settings.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 21, 2012 | D-Link DIR-615 Wireless Router
How can I add a brother 145 printer so all laptops in the house can use it wireless
This model printer has only an USB printer connection and normally connected to a computer or laptop.
To connect this printer wirelessly to all laptops on your wireless network there are a couple of methods.
Connect the printer to a desktop computer and setup the printer as a shared printer. Next connect the desktop computer to your wireless router with a LAN cable and then configure the wireless laptops to connect to the shared printer on the desktop computer. NOTE - This desktop computer and printer must be on at all times for the wireless laptops to print to the printer.
OTHER METHOD
Connect the printer to an USB print server and connect the print server to the wireless router with a LAN cable. The printer drivers needs to be installed on all the wireless laptops and then the printer port needs to be deleted from the USB port and a new IP address printer port installed. This IP address will be the IP address of the print server.
Jun 09, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a printer which is the canon imageRUNNER 2318 and i have to put it on the local area network.after signing the ip address to the printer still i can't print.the arrangement is like this there is a...
What you might want to do is reset the printer to its factory settings, which would include DHCP for the IP Address (your router will assign).
Then re-run the install of the FULL Printer software (drivers plus network scanner, etc.). With the printer on the network, when you run the reinstall it will scan the network looking for the printer and, in most cases find it. That way you know you have a working network and a working set of drivers.
If you then decide to set a static IP on the printer you can go into the Printer Properties on your PC and change the IP. If that fouls you up, you know how to recover.
Feb 25, 2018 | Canon Office Equipment & Supplies
Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
Having problems hooking my printer up on a home network using a wireless router. I have a desktop computer that has a printer hooked up to it through a USB cable as a local printer. My desktop accesses the...
You are using the wrong cable. Connect the printer to your router with an ETHERNET cable - not USB. Then then printer will have an IP address. Then it should be able to connect without the intermittent off and on that you have been experiencing.
Jan 04, 2009 | HP Photosmart C6280 Printer
Create a local area network
you can get a HP x175 printserver. (not expensive.) and connected it between the printer and the router. that way you don't have to have the desktop on all the time.
Dec 02, 2008 | Computers & Internet
How do i build a local area network in windows xp?
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at [email protected] and I will see if I can clarify this for you. Happy networking!
Internet connection lost when wireless printer added to network
for reseting the password of ur dlink router u have to press the rest button on the dlink router (genrallyit on the bottom or on the back of the router it is like a hole u have to use a pen or pin to reset the router back to its factory default settings after that password of the router will automatically back to admin or password login to ur router change the settings to static ip in the router so that u can provide the static ip of the other router to ur this router (example if primary router HL 2170 ip address is 192.168.1.1 then u will provide this dlink router the ip address as 192.168.1.5, subnet 255.255.255.0 default gateway 192.168.1.1 primary dns 192.168.1.1 now save the settings in the dlink router now the ethernet cable from ur other router will go directly in to the internetor wan port of this router. now connect wirelessly to any router both will work fine without any problem
Jun 03, 2008 | D-Link AirPlus DI-524 Wireless Router
Samsung 3160fn network question
You have to have the software set up on the laptop to be able to print from it. Also when you install the software make sure the laptop is hardwired to the router. I have found that if I try to set it wirelessly it won't work. I set it up hardwired to the router then it found it wirelessly. So make it short. Set up the printer on your laptop as though the laptop is actually a desktop. Then it will be able to find the printer wirelessly.
Also make sure that when you check the Network settings on the printer you have the same TCP/IP address for the printer in the PC and Laptops. I posted a long explanation on another post in this forum. You can take a look and find as a solution to someones network problem. The way I do it is to set up the router on the computer first. Hook up the internet to the router. Then set up all the other PCs on the router. Then hook up the printer to the router and turn it on. Then run the installation software for the Samsung and make sure you tell it the printer is set up on a network. See if the software can automatically detect the printer (it should). Pick your printer from the list of found devices and install it. It should work fine then. Also make sure that the Windows firewall is turned off when you do that or have it set to allow local network traffic. Good luck.
Mar 11, 2008 | Samsung CLX 3160fn All-In-One Printer
HP LaserJet 3330MFP All-In-One Printer Logo
61 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
