Question about Jl Audio 500/1 Car Audio Amplifier
Power when i power it up it only stays on for about 15 seconds then powers off. when i hook up my 300/4 it stays on fine
    Problem Solver:
  • 11 Answers
Bad ground.
Posted on Sep 06, 2007
I have an MTX audio JH 300 amplifier. When I turn the power off from the amp the yellow light comes on and stays on continuously. after about 15 minutes listening music amp shuts off, why
the light stays on because the amp is still storing power. it only turns off when the capacitors on the inside have drained off all the extra power
Oct 15, 2015 | MTX Car Audio & Video
Timer will not tirun on the lights, it stops when it gets to the time to turn on.
Malibu home page
Malibu manuals
Try the manual override >>> un-plug power pack and try loosening manual override with WD-40
It sounds like the clock motor is unable to push the manual override
Don't continue to run power pack or the clock motor will burn up or break a plastic gear
If manual override will not work, or clock will not trip on lights, you need a new power pack
Power pack size chart and wire length
Be sure to buy same wattage power pack as you have
The 300 Watt unit is made for 15 - 20watt bulbs (15 x 20 = 300)
If you buy 600 Watt power pack and hook it up to 10 - 20 watt bulbs, it will burn out the bulbs
Manual also says to replace burned out bulbs ASAP or other bulbs will burn out.
Oct 09, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Can you hook up two 12 gauge cables to the power pack of the ML 300 RTW transformer. Power cable would run in different directions. Thank you Joe
Hello yes you can the Important thing to remember here is not to exceed the wattage that the transformer puts out.
Add up the wattage of each bulb that you are running and ensure that you do not exceed 300 watts.
for example a 300 watt transformer could drive
a. 10 - 30 watt bulbs
b. 20 - 15 watt bulbs
c 75 - 4 watt bulbs
Its also ok to mix bulb wattage for example I use 10 watt bulbs in the fixtures in the front of the house but also power 4 20watt spotlights from the same transformer.
Hope that helps
Feb 26, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
Battery won't charge on my 3250
try the reset first, its the little pin hole on the side, hold it in for 3 seconds you may also press and hold the power button for 10 seconds...if those fail, hook it up to your pc via the usb cable and if it will stay on, go to the link below and get the lateset update for your model.
its possible it has a software or hardware problem and reset or update could repair it, but its not likely. this model and a whole lot of others are none for the usb port going bad and they are not feasible to repair.
Aug 22, 2009 | Magellan Maestro 4040 GPS Receiver
I have a RCA D52W20 52' It will turn on fine but after waching it for about 15 or 20 minutes it will blink to black and come back on for about 5 seconds then do it again then power off compleatly. You can...
it seems to be overheating, old tvs were hard enough to fix, lcds/plasma have less components but are costly to fix, i would recomend a serviceman as the cost of the parts are the biggest part of the repair
Jul 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Magnavox 15mf605t/17 15'' LCD HDTV won't turn on
Have similar TV. If it is set to the PC source, it goes into standby when there is no signal, like a regular monitor. Even though the monitor is in standby, you can still press the Source button to change to, say, HD input, and will use the familiar on/off action when pressing Power on the remote.
A little weird, but I've gotten very used to it.
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Trac Off and Engine light stay lit
well, the first to do is an oil service to your car, after disconnect the negative battery terminal few minutes to reset
Feb 14, 2009 | 1994 Lexus Es 300
Powers off after 15 seconds to 1 minute
solder issue at the flyback. try resoldering the flyback
May 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Power won't stay on.
There should be Two power wires connected one to constint power and One should be hooked to the power for ignition I also believe that there is a saftey that turns its off after so many seconds, There should be a way to disable that function in the owners manual, I sure Hope that helps you out Happy Holidays If not Lets fix it somehow just write back and let me know if that works..
Dec 14, 2007 | Bravo SD-20 Car DVD Player
Jl Audio 500/1 Car Audio Amplifier Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
