FixYa.com
Tags:
ECM Giotto Espresso Machine
Air pressure problem
posted by breijer on Sep 02, 2007
when I turn on my Giotto all pressure drops immediately when I use the steam option (coffee works fine) for the first time. After the pressure builds up again, all seems to be working OK. This happens each time when using the machine. So why is this happening and how can this be resolved? It never happend before.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 19, 2008
Not Rated (0)
moey007
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i have had this same problem and i can tell you for sure that the problem is the anti-vac valve. its a cheap part so you can replace it yourself but this typical with these machines, it prefers the steam valve to be opened when the machine is first turned on to avoid any annoying, sudden drop in pressure when first used.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 16, 2007
Not Rated (0)
brewerboy
Rating: 0%, 0 votes
I am having a similar problem.  Doesn't happen all the time, just sometimes.  My research has led me to believe it might be the vacuum breaker valve.  I am going to order a new one here:
https://www.chriscoffee.com/products/home/parts/vbreakervalve
I'll replace mine & post if it fixes it.
Good Luck
Can you Help with these Coffee and Espresso Makers problems?
repair to delonghi coffee maker...
hi i purchased a delonghi... Answer This...
kenmore coffee maker . press...
kenmore coffee maker 12 cup... Answer This...
Lever sticking
When I lift the lever to allow... Answer This...
wet grounds
Just bought a used ECM Giotto... Answer This...
Lift the lever, but nothing...
Giotto has worked fine for a... Answer This...
Repair Service
Find Coffee and Esp. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
