Rank: Wiz
Rating: 88%, 68 votes
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler
as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
