You can go to briggsandstratton.com , input your model and type number and get illustrated parts lists but as the other gentleman said if you want a Service Handbook youj are going to have to pay for that
I have an Airens 8hp snowblower that when it is in gear it won't move forward. It takes alot of...
(More)
I have an Airens 8hp snowblower that when it is in gear it won't move forward. It takes alot of force to move it but the augers move and the snow flies out of the chute good. What can I look at fixing?
I have a snowblower (MTD #195-990) that attaches to an MTD tractor #145-995. I have modified the...
(More)
I have a snowblower (MTD #195-990) that attaches to an MTD tractor #145-995. I have modified the snowblower to fit on a simplicity, however, I did not realize that the motors in the two tractors were installed in the opposite directions. Thus the snowblower is running in the wrong direction. I would like to get a schematic of the snowblower so that I can try to get another gear box made to have the snowblower operate in the proper direction. All it will take is another two gear gear box to fit on the bottom shaft of the existing gear box. I then can shorten the jack shaft to make everything operate correctly. So, I would like a schematic of the snowblower and/or the name of a place that sells or makes a gear box that I need. Thanks.
I have a jd 265 and the 20 amp fuse blows killing everything when i engage the clutch. This only...
(More)
I have a jd 265 and the 20 amp fuse blows killing everything when i engage the clutch. This only happens when you flip the switch while running,you can flip it while not running with the key on and can hear the clutch engaging. I took the clutch to jd dealer and the mechanic checked it and said it was ok.
