Question about Nokia 2600
Display problem my cell is show backlight once or not
  • 39 Answers
Software problem
Posted on Sep 03, 2007
SOURCE:
No light in a display
Your phones backlight might have worn so you were not able to get the light as the background..
This defect can occur due to the following reason
1)Software corrupted
2)Light must have worrn out..
If it is the first case, i recommend you to flash your cell phone with the latest firmware and try with that..
If your cell phone is not getting ready even after reinstalling your firmware,i recomment changing the backlight ..
Please leave me comment,if you need further assistance
Jan 26, 2010 | Nokia 5310 Cellular Phone
G1 backlight shows but nothing else
Everything is working fine except the operating system (firmware). A clear case of corrupted firmware. Please get the firmware reinstalled. And you will find that all your problems have vanished. The reason could be a virus or incorrect switching off or powering it on on low battery when the phone switches off on its own. Anything. But reinstalling is the answer.
Dec 12, 2009 | HTC G1 Smartphone
The monitor screen goes dark about 10 minutes
Please verify the power option setting present in 'control pannel' option once. If you have selected to turn off the power supply after 10mins, (once the system is in idle state) then the SMPS will stop supplying power.
thanks.
Jul 20, 2009 | BenQ FP71G 17" LCD Monitor
The wired keyboard backlight turnes off too quickly
You would need to go into the Setting Menu and find the Backlight or Power setting to lengthen the display and keypad backlight times. Just know that your battery life will decrease the higher the settings especially since it is a VGA screen.
Dec 18, 2008 | HTC Touch Pro Smartphone
My i-mate phone gives me troublesfails to recognize memory card,
First, you should backup your data. You should then download the latest firmware from i-Mate or your cellular provider (if available). You may need to unlock your phone if it is not unlocked.
Once the new firmware is installed, you should not have problems. Updating the firmware can be a lengthy experience. I would set aside 2-4 hours to upgrade and get your information back on.
A much faster method would be to hard reset the phone. If the problem persists, it is most likely a hardware issue with the backlight of the phone. It may need to be replaced.
Does the backlight turn on when the phone is booting up (after a reset or turning on)
Dec 01, 2008 | i-mate JASJAR Cellular Phone
My sidekick three has glitches and the backlight wont turn on
If the backlight on your sidekick 3 is dead, you will need to replace the lcd assy. They runa bout 30 dollars on ebay and are easy to do.
Here is a guide for the replacement of the lcd screen:
How to replace Sidekick 3 LCD Screen
find the screens here:
Sidekick 3 LCD Screens
I hope that helps everyone.
Nov 23, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Backlight display
Try setting & tools, display setting, and then brightness
Nov 13, 2008 | Motorola Mobility MOTO W755 Cellular Phone
Sidekick id backlight only works
physco2fresh
The lcd flrex cable may be loose. Is the screen white?
If so try this procedure to fix it.
Repair a Sidekick with a White LCD Screen
Jun 21, 2008 | T-Mobile Sidekick ID Cellular Phone
Broken backlight
if you open the v3 phone flip...you shall see 4 rubbers...remove the rubbers with a very small flat bit screw driver then unscrew the 4 screws in the phone then use the small flat bit onc more to open the phone cover, then remove the silver button on each side of the phone, unclip the cable leading to the camera and also the clip connecting to the lcd once those are removed then replace the old screen with the new one.
Dec 22, 2007 | Motorola Mobility RAZR V3
Nokia 2600 Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
