Question about NetGear RangeMax WPN824 Router
Netgear rangemax wireless router
Signal low and auto disconnecting
  • 20 Answers
Re: netgear rangemax wireless router
Connect with a cable and change the wirless channel on the router from normally 1 to anything between 1 and 11 try them all and it will get better
Posted on Oct 27, 2007
    Problem Solver:
  • 14 Answers
The thing you can do is move near the router or get a antenna.
Posted on Sep 03, 2007
0 characters
3 Points
How do i connect my netgear rangemax wireless router
You should have a manual/setup guide.
BUT, the basics of setting a wireless router are.
Connect an ethernet cable from your MODEM to the WAN port on the rear of the ROUTER.
Connect an ethernet cable from one of the LAN ports (usually 4) to your computer.
You now log on to your router via your web browser, set your wireless security (using WPA2) choose your password.
Save and exit from the router setup, disconnect the ethernet cable from your computer to the router and try and connect wirelessly
Your support page is here, choose which version of the router you have and download your manual
Aug 11, 2010 | NetGear RangeMax WPN824 Router
Problems with our wireless devices connecting to the netgear
Do you have a cordless phone in the area transmitting at 2.4megahertz?
If you do, that is what is breaking your connection. I found this out by accident.
May 27, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Experiencing disconnections
There could be other devices that run the same wireless frequency as your wireless network. You may want to change the channel on your wireless router or if you have an option to change other wireless devices at home such as cordless phone then you may do so. You may want to place the router away from those devices and put it in the middle of your wilreless computers to get better signal.
Jul 13, 2009 | NetGear RangeMax Premium Wireless-N...
NETGEAR rangemax router
make sure you have enable wireless in router setup page
if you are using USB key remove cable and see if you can see your network .... if not remove your usbkey and see if your laptop Recognize the disconnect ... need additionla info on yout setup if this does not work
good luck
Jun 07, 2009 | Dell Wireless 2350 Router
Netgear WPN 824 Low wireless signal
If you can access the router setup page, the best way to boost the signal is to change the wireless channel on the router setup page to a higher channel so the signal will be strong...
May 27, 2009 | NetGear RangeMax WPN824 Router
Low connection NETGEAR WNR854T RangeMax Next Wireless-N Router
Ok... Hate to be the bearer of bad news but this product has a bad reputation for disconnects and dieing after 6 months. If you're up for the challenge you could switch firmware versions to an open source version like tomato.
Mar 14, 2009 | NetGear WNR854T Router (WNR854T100NAS)
Netgear range max keeps dropping signal
Is it cable or DSL? Cable should be fine but DSL gets slower everytime a second or third connection is added.
Jan 04, 2009 | NetGear RangeMax WPN824 Wireless Router...
Can I use the Netgear Rangemax wireless router as an access point?
Yes you can use it as an access point and hook it to your existing router, since this is a wireless router and can work as a wireless access point on your network............
Nov 03, 2008 | NetGear RangeMax WPN824 Router
Weak connection with my xbox 360
The best way to make the wireless connection stable is to do some changes on the wireless settings of the router , like changing its wireless channel to the highest one to avoid any interference on your area.........
Sep 15, 2008 | NetGear RangeMax WPN824 Router
NetGear RangeMax WPN824 Router Logo
214 people viewed this question
Top NetGear Routers Experts
Level 1 Expert
 Mike M
Mike M
Level 1 Expert
Are you a NetGear Router Expert? Answer questions, earn points and help others
