Question about HP PSC 1410v All-in-One Printer
Can Not remove print cartridge from PSC1610
I inadvertantly put a black cartridge in the spot for the color cartridge and now can not remove it. Any help would be appreciated. It is an HP PSC1610 All-in-One Printer and hooked up to a Dell desktop computer running Win XP. Have tried to remove several times but did not want to use too much force for fear of damaging cartridge or print heads.
  • billf6330 Sep 04, 2007
    Thank you "guest" for the solution. The problem is now solved. Your answer was much appreciated.
    Thank you "guest" for your solution. It was very helpful and greatly appreciated. The printer is now working fine again.
HI BILLF6330 , YES DIFENTELY IF YOU FORCE MUCH CARTRIDGE ASSMBLY WILL DAMAGE SO DONT DO FORCE FIRST YOUR REMOVE ABOVE SCANER ASSMBLY WITH SIX STAR SCEW DRIVER AND REMOVE SCANER DATA CABLE AND SWITCH PANEL CABLE THAN REMOVE CARTIRDGE BALCK ASMMBLY WITH LOCK THAN REMOVE CARTRIDGE AND ASSMIBLE IT
Posted on Sep 04, 2007
My printer keeps saying "print head is not installed. Install the print head." I only purchased black ink this time and I put it inside but it still says that there is no ink. Do I have to buy the colour...
Hello, Jordanreinha -
You will need to install a color cartridge, too.
Oddly enough, with color printers, both the black and color ink/s are used to print black. Go figure?
Best wishes.
Feb 26, 2018 | Canon PIXMA MP470 All-in-One Printer
Tip
The green light is blinking constantly and the printer won't print
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
on Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
Where do I put the replacement cartridges?? I can't see where it goes on this printer???
here is your answer this was found here in your manual if you need it heres a link with picture instructions. start on page 15
MANUAL:
Open the printer, and then press down on the print cartridge carrier levers.
Open the color cartridge foil, and then remove the cartridge from the pack.
Remove the tape from the color print cartridge, insert the cartridge in the right carrier, and then close the color
cartridge lid.
If a black print cartridge is included in the box contents, open the black cartridge foil, and then remove the
Note: You may need to purchase a black print cartridge separately.
14 Remove the tape from the black print cartridge, insert the cartridge in the left cartridge carrier, and then close
the cartridge carrier lid.
Close the printer, and then load plain paper
Mar 26, 2010 | Lexmark X4650 InkJet Printer
I put the cartride in the wrong spot how do i get it out.
Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
Pull the print cartridge toward you out of its slot.
If you are removing the black print cartridge in order to install the photo print cartridge, store the black print cartridge in the print cartridge protector
Regards,
Jeep Brainy
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
I put in new color and black cartridges a couple of days ago and was able to print okay. Now I keep getting ''Remove and Check Black Cartridge'' prompt. I've taken out Black Cartridge, turned off printer,...
hope you put back both cartridges before trying again..try wiping the tip of the black cartridge before replacing it..then activate the head cleaning process..
Oct 03, 2017 | HP G85xi All-Color InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Canon Multipass F30 not printing
Did you remove the tab that covers the cartridge head where the ink comes out, if the drivers and software that you loaded on your pc work
good and your printer shows under device MGR, then it is the printer
itself,,most times you can not see how much ink in the cart,,,most are sealed,,,just try to put the cart in again and make sure it is locked in good,,try running the cleaning program with pc,,make sure the right
cart is in the right spot, bl in one spot and color in a spot.
Dec 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Spots/Lines on the prints
Take out the drum cartridge (piece with the long green arm) and look down inside the printer for any toner that may be leaking on your pages.
So I understand correctly, you were seeing different color toner on the cyan and yellow rollers?. If so gently clean that side of the roller off. Rotate the white gear on the right side of the toner cartridge back towards you and see if the correct color comes back on the roller. If you were seeing grooves on the roller then they will have to be replaced.
Put the toner cartridges back in and run color calibration.
Press menu/select. Right arrow key until you get to engine. Press select. Left arrow key until you get to service.
Press select. Right arrow key until you get to color calibration.
Press select.
Any other information would be helpful.
Jul 17, 2008 | Konica Minolta magicolor 2430 DL Laser...
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Dell A940 Color Ink Problem
Do check the option and make sure that you have not inadvertently set it to black only- This could be computer wise or on the A940 panel. If you are sure all is well here Remove the scanner software and reinstall. Email Dell to See what they have to say
May 08, 2007 | Dell A940 All-In-One InkJet Printer
HP PSC 1410v All-in-One Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
