Question about Mitsubishi WS-55809 55" Rear Projection Television
MITSUBISHI WS55809 Blue Screen
My DTV shows nothing but a Blue Screen. It was working and then there was a pop and the blue screen appeared and that all there is. The regular TV, Video and game channels all work perfectly. I do have an external HDTV reciever that is working.
  • Stress Sep 02, 2007
    It is when I switch the input to DTV that the Blue screen occurs.
    Sergeant:
  • 279 Answers
I'm not clear on this. When does it show a blue screen? When you have it in HDTV mode? A Blue Screen means it's not getting a signal (or the signal is very weak, resulting in more static than picture). If it is a blue screen for HDTV, how are you sure the HDTV receiver is working? If you can answer those questions for me, I should be able to track down the problem. I'm not sure which direction to go yet.
Posted on Sep 02, 2007
  • Anonymous Sep 02, 2007
    Double check your connections to the DTV port on the TV. If you have another TV you can hook it up to, that would be ideal to be sure it was the TV that was the problem.
    If you take the DTV cable out of the TV, and connect it to another TV, and it works fine there, then I'd say the most likely cause is the actual port the cable plugs into, or something on the board that port is on, at least. You'll probably need to replace that. However, I think it's more likely your cable itself is the problem, or the receiver.
SOURCE:
What's your question? I just bought Finesse tv but it does show any channels its just blue screen only ive tried to do automatic channel preset but nothing happens
The blue screen shows that you do not have a signal coming into the TV. So it sounds like you have the wrong input selected and or no aerial connected. Check the manual look for the inputs menu any cycle through them. My best guess is the DTV (Digital TV) input is not selected or you have it selected but no aerial plugged into receive a signal.
Once you have confirmed this run the automatic channel pre-set again.
Apr 15, 2015 | Televison & Video
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
My ws-55311 shows blue screen on all inputs except the DTV input
This set has 3 hidden menus accessed with a different 4 digit number code----You need the Mitsubishi remote to enter.
One of them is the Option menu which will allow a hard reset of the TV back to factory original---98% of the time it will restore all inputs--cures all sorts of odd problems.
If you have that remote and want to try it let me know for sure the model number and I will give you a link to the instructions for doing it.
Jun 16, 2012 | Mitsubishi WS-55311 55" Rear Projection...
Television comes on for a second and then screen turns black but tv still on
Does the OSD (on screen display) come up when you hit the menu button? If so try changing the input to the one you need.
Apr 04, 2012 | Televison & Video
Troubleshooting for maxent mx-42hpt51
hello!
Blue screen(bright blue) indicates an absence of signal. If you have "on screen" display characters: menu, channel ##, volume bar, etc, your set might be configured for digital antenna settings, or DTV, "air" mode. Then, you won't be able to get cable channels through. If your "blue screen" is dim and there is no any characters, then your Y-sustain module is bad. Especially, if you have encountered loud "pop" shortly before "blue screen" appeared. Then, it's a major repair with board(s?) replacement. If you can handle that, get back to me in a next session. I will guide yourself "how to".
Thanks,
Alex.
Feb 16, 2012 | Maxent MX-42HPT51 42 in. Plasma TV
Blue light is on and a blank screen on tv remote does nothing tryed hard reset with no change
Hello! Daniel Busa here with Dish Network customer service. The blue light simply means tv2 is up and running, you need to get the green light on. If it's still down hit th sat then power. If that doesnt work, hit the channel up button on the box system info should appear hit record three times, and then select, then power and it should start running again.
Dec 11, 2010 | DISH Network 322 DTV Receiver
Vizio LCD DTV 32 inch. Model L32. I can't 'scan' for digital channels. When I go to DTV, then Menu and scroll right or left to "TV tuner setup' I get a blue screen and nothing else. No key on the...
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Mar 23, 2009 | Vizio L32 32 in. LCD HDTV
Blue screen with dtv input and HD channels
the left large button controls a dozen different ways your set is hooked up,easest is get the monolink cord at any store will need a dvi hdmi.if not keep rolling the left large button,if you have a blue screen on all your inputs ,There has to a man around to plug in the right cord.
Jan 28, 2009 | Mitsubishi WS-55807 TV
Tv shows blue screen
my tv screen is blue and has a red key at the bottom left hand corner
Oct 04, 2008 | Apex Digital AT2002S 20" TV
Mitsubishi WS-55809 55" Rear Projection Television Logo
250 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
