Question about AT&T EP5962 Phone
AT&T EP5962 (5.8GHz digital Plus 2 Line)
The phone no longer takes messages. You call and it just rings and rings and rings. It says it has 50 new messages. If I hit the "line 1" the "line 2" or the "delete" buttons, the display says "mailbox is busy!"
  • 4 more comments
  • Anonymous Dec 31, 2007
    Messages are not recorded. When one calls in, it rings and rings and does not answer. When I try to reset the mailbox, it does not let me get in. The display reades: MAILBOX IS BUSY! The explanation in the manual says: Another handset (or base) has accessed the answering system. The manual does not explain how to resolve the problem. I am wondering if I can de-register all handsets and or bases...If you know of a fix, please let me know.
  • jack7794 Jan 29, 2009
    my mailbox "line 1" is flashing when I press it, the message "mailbox is busy" appears.
    I tested calling my number from my second line. I then pressed the blinking mailbox and again got the same message "mailbox is busy"
    After hanging up and picking up the phone, I did the Comcast beeping indicating I had a message instead of the regular line free signal.
    I dialed my own number to retrieve my message the Comcast way and could hear it, it was probably recorded by Comcast not my At&t phone.
    Normally, if I'm talking and a second call comes in, it is recorded in this way.
  • sndrinker Feb 14, 2009
    One of the four units, the main power source phone and handset, works, the others do not all of a sudden. I have tried a new battery and unplugging the power source on the remote chargers. No avail.
  • merry1932 Mar 02, 2009
    My 5.8 Ghz CORDLESS phone does not answer my messages anymore. All the caller gets is: "mailbox" to leave a message that I cannot hear anyway.
    How do I reprogram my phone so I can get my answering machine to register messages left for me???
  • Anonymous Apr 06, 2009
    answering machine part of the phone stopped working for no reason!
  • smilie467
    smilie467 Aug 27, 2012
    does anyone know how to set up a voicemail on this phone?
    Problem Solver:
  • 6 Answers
I had the same problem for months until I had a power outage and it cleared my phone. Try unplugging it for 10min or so.
Posted on Feb 25, 2009
Try unplugging your corded base unit, then replug. It should reset. Then you'll be able to go in and delete those messages.
Posted on Dec 31, 2007
I just had a similar problem with the "mailbox is busy" message while trying to retrieve messages. Instead of unplugging the power source as someone else suggested, I was able to solve the problem by unplugging the telephone line from the back of the phone. I was then able to retrieve messages. Then I plugged the telephone line back in and everything is working fine. This might work for your problem as well.
Posted on May 01, 2009
  • ep5962user Jan 05, 2011
    "mailbox is busy" error when I tired to access through "menu" or when hitting mailbox button. So couldn't get into the "mailbox menu" to set time, etc. I believe I got this error after a circuitbraker blew. Tried other suggestions with no luck. This is what worked for me:
    menu>set up base>deregister all (this means all handsets)> (when prompted "are you sure? hit>yes. Wait a moment until you hear a tone which means the base no longer recognizes handsets. Then follow instructions for re-registering a handset in the manual page 43. Viola!
I can no longer call in from remote location and pick up my messages. What is the process (code) for doing this?
Posted on Jun 14, 2010
When I'm on line 1, I can not hear the ring from line 2 if somebody calling me. what can I do?
Posted on May 10, 2010
I had to call the UK last week, and now the display on my phone only reads the number that i called. it wont go away and i can't check caller id or anything. i have unplugged the phone but it made no difference. what can i do to make this go away
Posted on Jan 26, 2009
  • rmm912
    rmm912 Apr 17, 2013
    I unplugged the power for a few seconds and everything worked fine
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
Mar 07, 2011 | Uniden DECT 6.0 Cordless Telephone...
How to set the time, and longer than 5 rings to my digital
its network dependant any network will keep the line for 30 sec only for ringing
May 24, 2010 | GE 29875GE Digital Answering Machine
Nortel T7316. We use auto assistant. Message picks up immediately. I want the receptionist to answer live and if she does not answer after a couple of rings for auto assistant message to kick in. How can I...
To change the number of rings enter Feature 983, if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant).
The 3 soft key selections GRTG, TABLE, and LINES
Press the LINES soft key
Enter the line number on the line you want to change ringing on (probably Line 1) and press OK
Press the TABLE soft key then the RINGS soft key
Press the CHNG soft key and enter in the amount of rings you wantand press OK
Press the NEXT key to go to the next line
Repeat the procedure for the remaining lines
Press Rls when finished
May 09, 2010 | Nortel T7316E 2-Line Corded Phone
Panasonic KX-TGA101 not working
By jim_giardine on Jan 03, 2010
My parents have had their Panasonic KX-TGA101 for a little over a year and it just stopped working. It no longer rings when a call comes in. Plus when we try to answer a call or place a call all we get is a busy signal both auditory and in the display window.
SOLUTION: you might want to change a new phone line, that's maybe the culprit, most of the time is the phone line is worn out first due to too many reasons.
Jan 03, 2010 | Panasonic KX-TGA101S Cordless Handset
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
answers after four rings when you have
no new messages and after two rings
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Sep 05, 2008 | AT&T 1738 Digital Answering Machine
Bellsouth answering machine
TS stands for "Toll Saver"
It will ring 4 times if there are no new messages waiting, it will ring 2 times if there are new messages waiting.
This has two effects:
1) If you are calling home to check your messages, you can wait 2 rings. If there are new messages to check, then it answers immediately. If you make it to 3 rings, you know there are no new messages and you can hang up before you are billed for your call. This was more useful when you would use a pay phone or hotel phone to make a long distance call home. With a pay phone you would get your "quarter" back as long as there were no messages. With cell phones,it isn't as useful.
2) If you not home (which is implied by the fact that there are new messages waiting), it answers faster, so people calling you don't have to wait as long. This could also be viewed as a security risk... it tells your callers whether you are home or not.
- Ben
Mar 13, 2008 | BellSouth Digital Answering System 2006C...
AT&T EP5962 Phone Logo
3,646 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
