Question about Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic DMR-ES46V shows F60 Error
Machine will not do anything. As soon as you press the power button the display reads F60 and stays there until you unplug it. When I plug it back in it goes through the startup process then shows the time. once you press the power button all you get is F60.
  • 4 more comments
  • Anonymous Dec 15, 2007
    cambridgejames
    I have a DMR-ES40V with the same sort of issue. I reset it (power button held for 20 seconds) a number of times, unplug, push eject, etc. Sometimes it comes back for a day and then stops again after playing a DVD. I throws error codes F03, F60 and U99 randomly but only during startup. If it starts working it stays working through a playing session but won't start again generally after that.
  • jahn May 17, 2008
    I have a DMR-EZ475V that does the same thing, F60, nothing happens
  • hardlyworkin Sep 11, 2008
    To the person who offered the solution -
    Are the ribbon cables easily removed from the video processor board; i.e., pull out? I purchased a second DMR-EZ475V on E-Bay for parts. Hopefully, the board swap is fairly simple.
  • Anonymous Jan 31, 2009
    I have the same problem with my unit. It started when the player would be turned off then suddenly it would turn on and off by itself then it went to the F60 code and will not work at all now. I took it to a local Panasonic rep come to find out it something wrong with one of the main boards in the unit and Panasonic no longer makes the replacement parts for it and it is unavailable. The only thing he could do is try to find one from another repair place. If he can't find one it is deamed unrepairable by Panasonic. This is the second Panasonic DVD player/recorder that I have owed and both have done the same thing. I will never, ever buy a Panasonic product again and will advise everyone to do the same. The are junk.
    Tim
  • chansard May 24, 2009
    Make me # 5 with the same F60 problem, take power off then back on & it runs through the 0000000 patern 2-3 times, then sets F60. Guess I will be at Best Buy tomorrow but not for a Panasonic. This machine has not been overused, we hardly ever use it.
  • Anthony Mercadante Oct 08, 2019
    Turned the power off for 10 mins. then plugged it back in pressing the power button, it cleared the F-60 error code.
    New Friend:
I have same problem with es40v - f60 error with no response to troubleshooting protocol. This machine also was used very little & also has a history of turning itself on. Panasonic used to make high quality products. A shame that their products are no longer trustworthy. I can understand that machines break - i'm very frustrated to learn replacement parts are not available. Guess i need to re- think brand loyalty.
Posted on Feb 12, 2010
  • 4 Answers
I called a local repair shop and they informed me that the F60, F61 etc codes indicated to check for a bad power supply first, and then the audio board after that.
Posted on Jan 27, 2010
F60 is a general error code usually related to a failure on the video processing board. If you have access to spare/replacement parts, this is an easy error to correct by simply replacing the board. You can recognize this board as the small board with the onboard HDMI port in the DMR-EZ47V model, and has the mini cables connecting to it. It floats above the rest of the boards in the middle back of the machine.
Posted on May 22, 2008
SOURCE:
Panasonic dmr-es40v
Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
Jul 08, 2016 | Panasonic DMR-ES40VS DVD Recorder/VCR
Code F60 on DMR-Ez47V
Unfortunately, the F60 error means that the video processing board (digital PCB board with the HDMI port on it) has a failure. Often this happens when the capacitors on the board fail. Replacing the board or the failed components on the board is usually necessary. Some of the components may be available here: https://www.encompassparts.com/model/MSCDMREZ47V/_/_/Panasonic/DMREZ47V/DVD_RECORDER .
First you can try to reset the unit. Unplug it. Then plug it in after a few minutes. Then when you see the string of 0's, press and hold the power button. Then try to power up the unit normally. Alternatively, press and hold Stop and Hold while you power on the DMR-EZ47V.
I hope this helps. Unfortunately, I am not sure which part number applies to the part you need from the PC Boards available from the site above.
Dec 13, 2015 | Panasonic DMR-EZ47V DVD Recorder/VCR
After power up, error code F60 is all I get. What's F60?
After reading and trying these solutions with out success, what I did was climb to the top of my roof and throw the Panasonic unit onto the cement driveway. The end result was the unit still won't work but darn I feel much better. No Mo Panasonic electronics for me, thank you very much!!!!
Sep 19, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Panasonic dmr-es46v player recorder error code u61. what do i due
That error means: There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
I suggest you unplug all the cords o the unit and after 2hrs replug and see if the error is gone.
Let me know the result.
Thank you for using fixya.
Jan 03, 2010 | Panasonic DMR-ES46VS DVD Recorder/VCR
DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Nov 13, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
I have a panasonic DMR-ES46V vcr/dvd HDMI i lost the instruction manuel and need to reset the remote to work agin i dont have the codes to do so all the display says is set 1 and the remote dosnt work
1) Hold The Enter Button Down On The Remote
2) Press And Hold The Numeric Button "1" For About 3-4 Seconds
3) Your Remote Is Now Reset To The Remote Control Code #1 (Default Setting)
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
PANASONIC DMR-ES46VS Front Panel buttons quite working
I have a Panasonic DMR-EZ47V. All of the panel buttons plus the remote will no longer work. I get a display showing F60. Unit is not very old.
Nov 06, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic dmres10 dvd recorder showing ' x hold '
This is the child lock feature, to stop unwanted use of the unit. Using your remote control, hold down 'enter' and 'return' until a message is displayed.
May 05, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES46VS DVD Recorder/VCR Logo
6,111 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
